Question about Pool & Spa
Powerfix drain cleaner ian109799 - Pool & Spa
Where can i buy powerfix safety shoes size 9 with velcro closures
I did a check and you can get them at Marks work warehouse.
Sep 09, 2014 | Clothing Accessories
Where can I buy drain daddy zip code 22408
http://www.qvc.com/Drain-Daddy-Set-of-2-Fast-Acting-32-oz.-Drain-Cleaners.product.V31981.html
May 25, 2014 | Drain Daddy Plumbing
POWERFIX 3 WAY STAPLER
It would be cheaper to buy a new one
May 19, 2014 | Tools & Hardware - Others
Need user instructions for Powerfix 9159 digital timer
Copy following link for possible manual:
http://waterheatertimer.org/pdf/Possible-manual-for-Powerfix-timer.pdf
Powerflix appears to be 24-hour 230Volt European version of 12-or-24-hour 120Volt UPM ET170 timer.
Copy following link to help identify timer buttons and download possible manual.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET170
Google search results show fixya on first page generally means there is NO information available on this device.
Oct 31, 2012 | Hardware & Accessories
Powerfix timer insrution
Aug 31, 2012 | Ace Hardware Hardware & Accessories
My Hayward pool sweep gets stuck when it goes over the drain at the bottom of the pool
It could be worn shoes on your pool cleaner causing the problem, but it is most likely just that you need to get a ring drain cover to cover your anti-vortex drain. It creates a smoother surface and is designed specifically to work with in ground automatic pool cleaners that are getting stuck on the drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Mar 19, 2011 | Hayward Navigator Pool Cleaner
Sticking solid to the bottom wont move.
If you have to much suction This can keep the cleaner stuck in one spot. Once the cleaner sticks to the floor the flapper won't move because of low water flo. If the cleaner only sticks when it hits the main drain then you still have suction through the drain and need to shut it down or plug it off. The suction from the drain and the cleaner suction will cancel each other out and cause the cleaner to stick to the drain. A main drain is a misnomer it is properly called a deep suction, as it's job is to collect heavy dirt. The cleaner is a roveing deep suction and replaces the main drain. So you no longer need it and can feel free to plug it if you have to. Good luck.
Dec 22, 2009 | Universal Kreepy Krauly In-Ground Pool...
Pool & Spa Logo
55 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
