Question about Industrial Paper Shredders Office Equipment & Supplies
Need to fix the power switch on my id armor shredder
I have the pieces just need a diagram or picture to put the pieces together
  • 3 Answers
SOURCE: ignition switch
Whoa....first, the ignition swith is not a part of the tumbler. you went in to far. replace the switch and put the brass gear on the tumbler. slide the tumbler out and install the keeper. the tumbler needs to be in the "on" position..
Posted on Nov 10, 2008
  • 15935 Answers
SOURCE: need a diagram on door handle how 5 pieces fit together
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
SOURCE: For the ID Armor ID-XC200D, where should I place
You don't use liquid oil. At the office supply stores they carry oil sheets that you insert just like shredding something. They come ion various pkgs. Staples and Office Depot stores carry them. They are universal, no model number needed. I hope this helps.
Posted on Nov 17, 2010
  • 142 Answers
SOURCE: I have a ID Armor
lots of shredders having problems like this. Easy way is to turning off the machine when you don't use it. Harder way is to disassemble it and clean everything you can. Maybe you will have to replace a sensor with new one. You have to spend some money:(
Posted on Feb 19, 2011
  • 72 Answers
SOURCE: I need to find a
The best thing for you to do is to go to your nearest Yammy Dealer and buy a good manual specific for that bike/engine. If there is no dealer near you, you could order one by phone from a dealer.
There are going to be a good many adjustments, and procedures, and tolerances that you will need to know, plus some special tools, and all of that will be in the manual. It will have complete engine, and chassis breakdown pics, and all procedures for complete teardown and rebuild.
The chances of you finding all you need to know online are pretty slim, and you will need a manual later, anyway, just to properly perform the maintenance on the bike/engine.
Posted on Jun 23, 2011
Where can i buy parts for my id armor shredder
Your question, while it does state "parts," doesn't specify which parts. The reason why my answer isn't going to tell you, is because the "parts" can vary from the safety flap all the way to the motor that drives the shredder blades.
My suggestion is that you find where you can be eco-friendly with the shredder's disposal and purchase a new one. If you are looking for a part that has anything to do with the workings of the shredder (blades, on/off switch, paper sensor motor), you are going to wind up spending almost as much as a new one would cost and perhaps even more. Plus you have to take into consideration, the time you would spend doing the repairs; surely your time is worth at least $10 an hour. You are most likely going to spend too much time making the repair. Believe me, I tried to fix one once (it was successful, just the "bellows" that expands to change the setting of the "normally off" micro-switch back to off) and it took me a couple of hours.
Purchase a new one and forget about "saving" money by doing the repair yourself.
Jul 13, 2014 | Staples ID Armor IDX50B Shredder
Beeps and stops; doesn't stop when empty
As for your first part - It sounds like there is something wrong with the switch lever that moves to complete the electrical circuit to start the shredder. On every shredder I have seen, there is a little "bellows" linked up to this lever that pushes it back so the machine will shut off. Most of the time all you have to do is put another piece of paper in and let that get shredded and the shredder will stop afterwards. If not, then just use the main switch to turn the shredder off.
Second, the beeping during "mid-shred" sounds like a warning that the shredder is starting to overheat and shut down. If this is the case, just wait a few minutes to allow it to cool down and try to finish the shredding you have. I have found that if you feed a shredder a constant stream of paper to shred, this might cause the shredder to overheat.
Also, the shredder may get overloaded with pieces of the shredded paper. Here is the way to check on that:
2. Lift the shredder from the bin and turn it upside down.
3. Look for an excessive amount of paper in the bottom of the shredder. If there is a lot, you can remove it in several ways. (Most likely the bin is quite full at this point.) Pull the majority of it out and put it in the bin. If there are pieces of paper that you can pull out with your fingers, use a tool (needle-nose pliers, serrated tweezers, a hemostat, etc.) to get those difficult pieces out.
Replace the unit on the bin making sure that it is the same way you took it off. In most cases (on the better shredders), there is a notch on the underside of the shredder that needs to be on top of a "nub" that is on the edge of the inside top of the bin. Unless that nub is aligned with the slot, the shredder will not work.
Apr 26, 2014 | Staples ID Armor IDX50B Shredder
Shredder won't shred does it need a security card?
I believe that it could be one of two problems. First of all, and the painfully obvious one, do you have the red power switch in the on position. Try moving it to different settings to see if it does work at all. If it does, put the switch back in the center position and try shredding again. If it doesn't work, then you may have a faulty shredder. (This and the following are believing that you have a new shredder and you are trying to get it to work for the first time.) Second, if you lift the unit off the paper bin and look on the bin, you will see a slight protrusion, like a "tab." When you place the unit onto the bin, this tab must be aligned with a slot on the shredder unit; the slot will have a small strip of silver metal inside, it is part of the safety mechanism. If you are using a trash bag - to make for easier shredded paper disposal - you might have to use a bit of pressure to make sure the tab makes contact with the little piece of metal. You also may have to turn the shredder unit around 180 degrees and re-seat the unit.
If it still doesn't work, call the service/warranty/support department and find out what you need to do next.
Mar 05, 2014 | Staples ID Armor IDX50B Shredder
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
Mar 05, 2014 | Fellowes Office Equipment & Supplies
Motor is burned up, would like to purchase a repacement motor. modle # ID armor ID 1506x
Have seen many people looking for parts for these small shredders here on fixya....have not seen that you can buy parts anywhere yet...
They really don't want you to fix them I think, they want you to chuck it and buy new...
May 24, 2011 | Staples ID Armor IDX50B Shredder
1050lbkx, I put too many pages in. It jammed. I removed most of the pages and now it won't move and screeches.
If it has a reverse switch try cycling forward and backward some.
Get some WD-40 and spray that into the teeth. Let it sit for a while then try cycling it again.
Worst case, if it has soft gears, the over-taxing of the motor might have stripped or damaged the gears.
Mar 01, 2011 | Staples ID Armor IDX50B Shredder
For the ID Armor ID-XC200D, where should I place the shredder oil?
Nov 02, 2010 | Staples ID Armor SH2836ID2836 Shredder
It doesn't even power up- could I have burned out the motor? The strip it's plugged into is working with other machines
Did you remove the top to clean recently? You may not of installed it correctly. Keeping the saftey switch from making contact. It thinks the top is still off and it won't run without the switch making contact. Try resetting the top a couple of times to insure the switch is tripped.
Jun 28, 2010 | Staples ID Armor SH2836ID2836 Shredder
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
50 people viewed this question
Top Industrial Paper Shredders Office Equipment & Supplies Experts
Level 1 Expert
Danny Kuhlmann
Thomas Stauber
Thomas Stauber
Are you an Industrial Paper Shredders Office Equipment and Supply Expert? Answer questions, earn points and help others
