Question about Vizio 42 Class 120hz - 3d Hdtv Lcd E3db420vx 1080p - Vizio
I have a vizio E3DB420VX television and there is a black screen problem can you help
As I said with my vizio when I turn my television on after being off for a while there is a black screen except for a small picture on top (the sound is fine) for about 15 to 20 minute and the the picture is fine
  • Vizio Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here
Posted on Dec 27, 2016
Vizio E3DB420VX horizontal lines on lower half of the screen, what part will fix this? This is on all inputs and occurs also on the menu screen above the words.
The buffer board connection to the display screen on some ( few) models have ic's that fail and can be replaced. Not cheap and requires skilled tech and tools. often, confections at screen can be poor, some foam stuffed in open space between edge of screen and front cover can make connection better, not often very good or permanent.
Nov 30, 2016 | Vizio Televison & Video
Vizio tv won't power on
Could be an open internal fuse or power supply failure
Aug 03, 2016 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
Vizio 55" M550NV turns on, screen displays Vizio symbol for a few seconds then turns black but the tv stays on. What is this and how can I fix it?!
Hi Tiffany, The link below is a YouTube video showing how to fix a Vizio television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 07, 2016 | Vizio Televison & Video
Have a 50 inch vizio when u turn it on the lite in front turns white but no pic black screen any ideas
you will need to check your power supply!
All televisions wich have tese problems with starting faulty and screen staying black have power issues!
Apr 05, 2013 | Vizio L32 32 in. LCD HDTV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
Vizio E422VA 42 in LCD television power light blinks
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
Mar 04, 2012 | Vizio GV42L 42 in. LCD Television
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Jan 24, 2010 | Vizio VX37L Television
Vizio p42
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
Feb 01, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42 Class 120hz - 3d Hdtv Lcd E3db420vx 1080p - Vizio Logo
62 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
