Question about Sony Playstation 3 (PS3) Console
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
I try to turn on my ps3 but after 2or3 sec it turns back off and just blinks red
  • 6,784 Answers
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Posted on Jul 21, 2009
When turned on, the power light changes to green for a few sec. then starts blinking. After a while (30-60 sec.), power light changes into red and blinks...
Sorry, but you need to have a service tech fix it. Do not try yourself or you will be getting a new TV.
I know you don't want this, but..........
Sep 07, 2011 | Panasonic PT-60LCX64 Television
My tv wont turn on i have a toshiba regza. when i do turn it on the red light in the front blinks every few secs over and over for as long as its plugged it. i tried a few things but still no solution....
The first thing to try is to unplug the TV, leave it unplugged for about 60 sec, the plug it back in. If the problem persists, this is most likely an issue that will need to be resolved by an electronic repair store/facility.
May 06, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Kodak camera C653. Camera will not come come on after green light blinks.then the red light blinks and the camera goes off Batteries is not the problem
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Kodak EasyShare C330 Digital Camera
When i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
Hi, Does the set come on for about 30 sec.? I had a 50V715 hitachi, it came on for about 30 sec. then shut down and then it would repeat the process. After about 3 wks and alot of other pain, it turned out to be the lamp was weak. Replaced the lamp and all is great! So... it could be your lamp is going bad. Hope this is helpful.
Nov 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Power light blinks red
first try unplugging it and let it reset, for at least 3 minutesthen try it again
May 30, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Sony Playstation 3 (PS3) Console Logo
228 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
