Question about Vacuums
The beater bar on my vacuum does not work. This has happened numberous times since I have had it. It has been cleaned from head to toe according to all directions and it still does not work
    Top Expert:
  • Vacuums Master
  • 46,465 Answers
Sadly we have no idea here , what machine you refer to .there fore we can not assist . try the manufacturer's website
Posted on Dec 27, 2016
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
Vacuum doesnt pick up very well any more
Larry Kessler:
Unplug the vacuum and lay it down on the floor upside down on some newspaper. Remove the vacuum head foot plate with a Phillips head screwdriver. Remove the beater bar and belt by pulling straight up on the beater bar. Pull the end caps and bearings from the ends of the beater bar... it may take a two-grunt pull to remove them, or CAREFULLY use a screwdriver to pry them off. Remove the hair, carpet fibers and other gunk from the ends of the beater bar, bearings and end caps. Pour (or spray) alcohol on the bearings and spin them until they spin freely. Dry the bearings so there is no alcohol in them.
Put a few drops of light machine oil in the bearings, (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure the bearings spin freely. Now would be a good time to check the vacuum head opening and the hose for clogs. Reassemble the end caps and bearings to the ends of the beater bar and reinstall the beater bar assembly (with a new belt) in the vacuum head. Reinstall the foot plate, and your machine should pick up fuzz balls the size of Michigan!
Feb 15, 2013 | Vacuums
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION VACUUM CLEANER?
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
