Question about Cuisinart Coffee Makers & Espresso Machines
Cuisinart on demand drips - Cuisinart Coffee Makers & Espresso Machines
Why do I get so many coffee grounds in my cuisinart on demand coffee maker?
Many times this is a result of the coffee grind. To overcome this with some brands, I use an additional filter, put the desired amount of coffee in it, and then fold the sides over to make an envelope. Place the folded sides down and brew coffee. If any of the coffee gets out, the second filter should catch it.
Mar 25, 2015 | Cuisinart DCC Coffee Makers & Espresso...
Coffee drips how do you clean reserve
Fill the pot with viniger at least up to half, Pour it in the researve tank end let it go though as if your makeing coffee with it, Do that 2 times, Then after it is finish doing the secound pot,leave it in for 30 minutes. Dump it out, Then do the same (Again) But use (water) to do it with, Once the .2 pot of water have gone though it ,then it is ready to use again, this should claen it up for you.
Oct 26, 2012 | Cuisinart Coffee on Demand 12-Cup...
I have a Cuisinart Coffee on Demand maker and it will no longer brew. Its less than a year. How can it be fixed?
mcdevito75 here, May need to be cleaned a swater will leave deposits, refer to owner manual for cleaning.
Jun 22, 2010 | Cuisinart Coffee on Demand 12-Cup...
We have a 2 year old Cuisinart coffee on demand and it just stopped coming on. We turn the buttons and nothing happens.
We had the same problem. Ours was 2 1/2 years old. The warranty is three years on the 'Coffee on Demand 4000'. If you sent in the warranty card or went online and did it when you bought the unit you can get a replacement at no cost. You'll have to cut 3 inches off the cord and send to them.
The toll free number is 800-726--0190 Good luck!
Oct 23, 2009 | Cuisinart Coffee on Demand 12-Cup...
Drips after brewing from where coffee comes out
I have this model as well with no problem, but it replaced a proctor silex (i believe...) that did have this problem. there were replacement seals supplied with the Proctor Silex, but not with the Cuisinart. A quick look at the Cuisinart website turned up no part readily for sale. I would call the company to see if they can supply one
Jul 10, 2009 | Cuisinart Coffee on Demand 12-Cup...
Cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Jun 16, 2009 | Cuisinart Coffee on Demand 12-Cup...
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
