Question about LG Televison & Video
Have connected lg sound bar to lg tv var optical lead but every so often it all turns off. Tells me to press any button to stop this but it does not
james tv man
  • 91 Answers
SOURCE: I have a 50 inch LG plasma tv, not sure of the
The optical output is always on.......you will see that the cable is lit up at the end when you plug it in........you may have to set your sound bar for the optical input though........do you have that manual?
Posted on Jun 02, 2010
bshldn
  • 736 Answers
SOURCE: I have a Samsung hw c-451 sound bar.I have it
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
Posted on Jan 27, 2011
sethtorvea
  • 17 Answers
SOURCE: LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
Posted on May 08, 2014
SOURCE: I am trying to connect a lg sound bar to a
If you have a digital coax out, or vice versa, they make digital optical convertors. Try MCM Electronics.
Posted on Dec 12, 2014
  • 1552 Answers
SOURCE: how to connect my tv to optical outlet
What audio-outputs does your TV have? SPDIF? 3.5 millimeter stereo-jack? White/Red RCA "post-and-collar" sockets?
What inputs does the sound bar have? (Same choices as above.)
Note that you might need a 3.5mm to stereo-RCA cable.
Posted on Feb 09, 2015
Just purchased Rico bos90. Put optical cable from my lg tv to the optical on the sound bar. No sound whatsoever
You may need to configure either the TV settings or the sound bar to use the optical connection. If both have HDMI connections, you might consider that connection method as an alternative.
Aug 03, 2016 | LG Televison & Video
How do i connect a LG sound bar to a sharp aquos
optical out of tv to sound bar. if not come of your cable box optical...
Sep 30, 2015 | LG Televison & Video
A LG soundbar to a Laurus TV I've fix a optical lead one end and jack plug on the other but it doesn't work
A fiber optic cable carries infrared light path only. It's a digital signal, you can only connect this to equipment that has an optic connection. Adapting it with any kind of analog jack just simply won't function.
laurus tv images Google Search
checking the Google images of the Digital module does not show a tos-link connection for the module.
Apr 17, 2015 | LG Televison & Video
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Mar 27, 2017 | LG 42LC2D 42 in. LCD HDTV
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Televison & Video Logo
