Since the plumber unclogged the kitchen sink, water doesn't go into the dishwasher. The unit turns on & runs, but no water enters the DW on any cycle. The plumber did drain the unit after he fixed the sink, by holding 2 of the control buttons on the front, but he didn't do anything inside the DW.
Bosch SHU43C05UC purchased 10/2003
I checked the water-in line to make sure it was open, cleaned the filter, reseated the bottom spray arm, I'm lost as what to do next. HELP!
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Comments:
Jul 21, 2009
- The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
I had the same problem with my Bosch dishwasher. It was the water inlet
valve and not the float. I installed it myself without much difficulty. It's a $35 part.
My Bosch classixx has started making a terrible squeaky noise during the cycle. And it isn't...
(More)
My Bosch classixx has started making a terrible squeaky noise during the cycle. And it isn't washing stuff as well. I have checked the spray arms and they are not blocked and they are able to turn.
Hi Display timer is incorrect resulting unit not working is there a way reset I had it service once...
(More)
Hi Display timer is incorrect resulting unit not working is there a way reset I had it service once prior and i believe it was some how reset
the door handle is loose, how do you take the soap dispenser off so you can seperate the door from...
(More)
the door handle is loose, how do you take the soap dispenser off so you can seperate the door from the inside panel
