Question about Sewing Machines
My lovesac is getting a tear near a seam. Should I sew it or is there a special patch?
  • Sewing Machines Master
  • 11,444 Answers
Depends what the fabric is. However, for longevity, handsewing the tear will probably hold up longer than any glue or tape product.
Posted on Dec 27, 2016
How do I set the machine to make a rolled seam?
fit the correct sewing foot for starters
it has a special shape the rolls the material over before gets to the needle Available from any good sewing shops.
select the correct program and that will be it
May 25, 2015 | Sewing Machines
When zig-zagging on raw edge stitches bunch
Use a different stitch, use the triple zig zag or serpentine stitch so he needle is going through the fabric three or four times as it swings left to plain zigzag, because thread is tensioned, will pull lightweight fabric up. Try another raw edge finish, such as french seams, pinking shears or overcasting stitch. Of course for professional looking seams an overlocker (serger) is the answer as it has blades that trim the fabric edge and neaten with 2, 3 or 4 thread seam, encasing the raw edge.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area:
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
Thread pulling fabric through feed dogs
Usually when that happens you have the wrong needle plate on for the fabric. Now if you don't have an extra needle plate.... try floating a piece of tissue paper or tear away stabilizer between the fabric and the feed dogs. When the seam is finished just tear away the paper or stabilizer.
Another thing sometimes the problem lies in not having a long enough stitch for the fabric.
Mar 10, 2013 | Sewing Machines
Mending the shirt elbow with a patch
if shirt is a fabric that ravels easy, you might want to put a patch on the
outside & then put a patch on the inside of the sleeve, try to match the
patches up as evenly as possible. just make sure the patch
covers the tear or hole.
Apr 26, 2012 | Sewing Machines
I have a 1970's era sewing machine (an almost antique) & I cannot change the control for zig zag or any other design - the control seems to be frozen. This machine gets very little usage...
I would suggest to take it to a sewing machine repair shop, a sewing machine is like a car once in awhile they need to be serviced, checking for loose or broken parts, getting greased & oiled, is the life of the machine, it help the machine last even longer.
Sep 13, 2011 | Husqvarna Sewing Machines
I have a brother VX-950 sewing machine I have a pretty good stitch on top and bottom, put it is still puckering. I tried the tension. What elese should I try?
New needle and make sure it is the right sized needle for the fabric that you are sewing. If silky satin then use a size 70 or even 60 needle sharp. If microfibre then there are Schmetz needles called microtec that are perfect for this.
Also try shortening the stitch length a little. You may still need to finesse the tension a bit. I think this is a front loading bobbin machine so you might try adjusting the tension on the bobbin holder a little bit. It is hard with these as there is no "0' marking to set it to, its just trial and testing.
Also, are you pinning across the seam line at about 3 inch intervals?
If there is still some puckering happening, then perhaps, stop at the end of the seam with the needle in the work, and ease the fabric along the stitching line a bit to smooth out the seam, then do the reversing stitches at the end to lock off the seam.
Also press, press, press each seam. Always press on top of the seam, turn it over and press the underside of the seam, then lie right side down on the ironing board and press the seam allowances open. This sets the stitches into the fabric and finishes off the seam appearance. I always sew with the ironing press on beside me.
You may still be unhappy with the seam result after doing all this - if you enjoy sewing then consider shopping for a higher quality machine - there is a difference in stitching quality between a $400 and $2,000 machine. You could always take a piece of your fabric to a sewing dealer near you and test sew on a European machine, you should see a difference in the stitching quality.
Apr 17, 2011 | Brother Sewing Machines
The material sticks in the hole in the bobbin part of the machine
Try using a tear away stabilizer, or gift tissue paper, even computer paper will work to get you started if your material is too thin. Also, use the right size needle and hold your threads when you are starting to sew a seam
Mar 15, 2011 | Sewing Machines
I am sewing on 100%polyester silk and using a 65 needle and the tension is on 4.2, stitch length 2. The fabric keeps wrinkling. I've tried rethreading, checking the bobbin and changing the tension. Nothing...
There is a pressure adjustment for the presser foot.
This is usually on top of the machine, over the presser foot.
If it resembles a screw head on this model - a dab of nail polish or mark of a sharpie will help when you reset after sewing sheer fabrics.
If you move the adjustment to the left it will reduce the pressure and should also reduce the wrinkling.
Adjust and then test on a sample of the same fabric you will be sewing.
Be sure to re-set after sewing thin fabrics.
Refer to the manual or download a free one at Brother's website.
Feb 22, 2010 | Brother XL3750 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
