Question about AMP Cell Phones
Hi there. I'm looking to connect a portable turntable to my arcam amp and speakers.
Can you tell me what kit/cables I need plz.
informatica
  • 1114 Answers
SOURCE: connect turntable to NAD S300
Yes you will need a pre-amp for your turntable, there is no phono input on this amplifier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 09, 2007
  • 275 Answers
SOURCE: Connecting speakers to amp
Your Amp will be having a pair of Phono / AUX input sockets at the rear. Connect the two Red and White cabbles from the Turntable to these sockets. I am unaware of what are Pilot Speakers. regular speakers have a dual colored pair of cables coming from them. they have to be connected to the speakers Connectors at the rear of the Amp. Play a Vinyl Record, select Phono on your AMP, and enjoy your music.
Posted on Sep 17, 2007
SOURCE: I have recently purchased a arcam alpha 10 amp to
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
Posted on Jun 22, 2009
  • 122 Answers
SOURCE: connecting a sonos 90 to BO 8000 active speakers
beolab 8000 speakers have a line input ( rca phono) which is switched at the rear connection,this is monitored for sound so will turn on/off on their own.you must use a pre-amp or a variable volume output as a source.
Posted on Dec 14, 2009
  • 155 Answers
SOURCE: I tried connecting my old Technics turntable using
you turtable will need a pre amp especially if you have a magnetic pickup cartridge
Posted on Sep 14, 2010
Arcam alpha 10 only one channel works, how can i check it or fix it
Swap the speakers. If the problem follows the speaker, then it's a speaker issue. If it stays on the same channel., then it's an amp issue.
Try other source inputs. Is it the same on them? This tells you if it is a source/input/cable issue or a problem with the amp itself.
Fixing it depends largely on what the issue is, and how skilled you are with electronics. The issue could be something as simple as a bad cable or poor connection. Or it could be something age related such as dried out capacitors in the power amp stage, or maybe a blown output transistor pair. Go for the simple troubleshooting tips above and eliminate any basic problems before looking at more complex solutions.
If you're expecting as "press this button and all will be well", then sorry, you can forget that.
Stereo amps are old skool. There's no resets or apps or microprocessors. If something doesn't work then it's because a thing is broken. That means lifting the hood and getting dirty hands.
Sep 02, 2014 | Audio Players & Recorders
I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
Apr 19, 2013 | Audio Players & Recorders
Arcam A65 amplifier keep on go to standymode why?
Depending on the volume level and how many speakers you are driving factor into how the amp will react. Check the speaker wires for shorts, if okay! then we must look at the audio output stage, if the semiconductors are getting to hot, the satety circuits will cause a shutdown, if you run a pair of speakers the amp will run cooler, if you recently added more speakers that would explain the shutdown, if not! there is a problem in the audio output transistors and ic's that will need to be dealt with.
Apr 14, 2012 | Arcam Audio Players & Recorders
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
My Arcam AVR250, shuts down when attempting to iniatialise, linked with relay click. Sometimes it goes beyond iniatialising and displays the last selected input and db level, and then it clicks and shuts...
In that case, you most likely have a shorted MOSFET on one of your output channels. The unit is going into protection mode.
This can be caused by shorting your speaker cables or overdriving a speaker.
If you have the skills it is a job that you can do but you would need to find a service manual for the unit and replace the output transistors. You would also need to check some associated circuitry.
A good repair shop should be able to do this for you but you are probably looking at $150+ to do it, maybe more.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 20, 2010 | Arcam AVR-100 Receiver
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
May 04, 2009 | Audio Players & Recorders
Hum from B&o active speakers
hi , i just saw ur mail although I do not have the solution to this but I am keen to know how you are using these speakers as I too have identical beolab 6000 and beolab 9000. I was thinking of connecting them to a preamp. What do u suggest ? Pls guide
Oct 01, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Sep 15, 2007 | Audio Players & Recorders
Cell Phones Logo
Top AMP Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AMP Cell Phone Expert? Answer questions, earn points and help others
