Connecting a turntable to alpha 8r - Audio Players & Recorders
Where can I get repaired in Mumbai .
Sai raj electronics
Behram Baug-Jogeshwari West'More...
Oberoi Electronics
+(91)-22-28713472, +(91)-9819219720
Bangur Nagar, Goregaon West'More...
Alpha Vision Electronics
+(91)-22-21023086, +(91)-9869359839
B Mehta Marg, Ghatkopar East'More...
Sep 26, 2014 | Crosley Brand New Cr66 Rochester Stereo...
While recording and playing back the recording it sounds like there is cell phone or some electrical interferrence. this happens to the cassette and vinyl converts
There could be a loose connection between the turntable and the recording device. Normally, the connecting cables are shielded to prevent this sort of problem. Maybe different connecting wires are in order. Is your recording setup located near fluorescent lights or some other interference causing source?
Sep 26, 2012 | ION Audio iTTUSB Turntable
I have a lexicon alpha, samsung CO1 condenser mic and a samsung phantom power box, i have all the correct wires but i dont think i am connecting the correctly, HELP ME ! lol
Sorry, but the Alpha does NOT have Phantom power which IS required for a condenser mic.
You will either have to get a mic preamp that supplies phantom power or go to a dynamic type mic if you stay with the Lexicon Alppha.
Jan 17, 2011 | Lexicon Alpha Personal Recording Studio
There is very low sound from turntable to teac
Check out if the earth connections are are good in the jack.
Are you connecting to a dedicated socket for turntables on your amp? Turntables have to have a pre-amp stage (unlike CD/Tape) before they go to the main pre-amp. If the Teac doesn't have a turntable socket, you will need to buy a pre-amp for the turntable.
Jan 20, 2010 | Audio Players & Recorders
Flash compatibility
According to what I read the sunpak dx-8r is, with the right module, compatable with digital SLRs. Check with B&H photo to get the right module.
Apr 21, 2009 | Sunpak DX-8R TTL Ring Light Flash
I need a grounding wire to connect to my Griffin Imik
not sure I fully follow your question but the 3 rd ground wire from the turntable would hook up to the ground screw on the imic
Jan 21, 2009 | Teac P-A688 Turntable
Sunpack DX-8R
You will need the proper module. Check with B&H photo for the module compatable with your Olympus camera body.
Nov 26, 2007 | Sunpak DX-8R TTL Ring Light Flash
Superserver 6023-8r
if you have enough hd space and memory , just install ms virtual server / install server os , and you will be able to use as another server (virtual server).
you can connect to it by name / ip address etc., just like a real physical server.
good luck
Oct 09, 2007 | SuperMicro SuperServer 6023L-8R
No Sound from Turntable
It definitely has to go through a preamp (a PHONO preamp that is...) something like this:
Sep 14, 2007 | Nakamichi AV-7 Receiver
44 people viewed this question
