Question about Polaroid Tablets & eReaders
Polaroid 10.1 tablet no sound unless on the charger
I need to find a charger for my Polaroid tablet model number a8 and it's a 4gb
http://www.amazon.com/Charger-ADAPTER-Polaroid-Tablet-PMID705/dp/B00BYK297M
Jan 02, 2016 | Polaroid Tablets & eReaders
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Jan 01, 2016 | Polaroid Tablets & eReaders
Setting on charger for a Polaroid tablet, 6V, 12V, Help
Not sure of the model number of your polaroid tablet you have. Generally the adapter should be an AC adapter for 220V or 110V depending on country. It is unlikely you will have to select 6v or 12v. If you are unsure charge the tablet through the USB cable connected to a computer. It might take a bit longer to charge and make sure the computer is connected to mains charger to avoid drain on computer (laptop, etc) battery.
If you have a 7" tablet then I am assuming it is a PMID705. See manual on this link.
http://www.southerntelecom.com/upload/polaroid/pmid705/PMID705_User_Manual_20121210.pdf
The manual says it is a 5v DC output connector for the adapter. Not sure why you are asking the question. If in doubt send email to polaroid support on the address at end of the attached manual.
Sep 19, 2014 | Polaroid 7-in. Internet Tablet - Other
My tablet wont charge what can I do I try to plug in charger but won't charge the battery even bought another charger still dont help
Most likely you are using an aftermarket charger. You may want to purchase another or buy and OEM charger.
Jul 09, 2014 | Polaroid 4.3" Internet Tablet
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
Forcd Factory Reset
best learn the principles of your tablet first
first when a battery is less than 10% it takes up to 5 hours to recharge not 5 minutes
next many tablets do not recharge when in operation so you have to shut down to allow the recharge to work
because the battery was dead flat , of course it will reset as that is the same as removing or installing a new battery
Nov 11, 2017 | Polaroid 7-in. Internet Tablet - Other
How do i fix my tablet?
First off I was ask do you know if the charger is good? If it uses a USB connector to charge and you have another device with a charger, try swapping it out. Look on the tablet charger for the Volts (V) and the Amps (A) it will probably be 5V and 1-2A if you have a charger with a fairly close rating it should charge the tablet. You may also need to hold the reset button down for up to 20 seconds.
Jun 18, 2013 | Tablets & eReaders
Why won't my Polaroid 7" tablet charge?
My polaroid does the same thing just hold the charger in while pushing it down but it will take a while
Aug 13, 2012 | Polaroid 7" Internet Tablet Android 4.0...
Tablets & eReaders Logo
35 people viewed this question
Top Polaroid Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
