Question about Bodum Coffee Makers & Espresso Machines
My red button on my BODUM COFFEE GRINDER 10903 is not working and do not give the contact to the grinder
SOURCE: Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Posted on May 21, 2008
SOURCE: Stuck grinder
Thanks! It does not seem to be damp. I emptied the bean box and vaccum cleaned the grinder - I did not see any beans blocking the grinder. What would the next step be?
Posted on Aug 30, 2008
  • 1089 Answers
SOURCE: Saeco Italia Sup021 YR flashing red malfunction light
HI
If you don't hear the grinder motor, I would say you have a disconnected grinder wire. These motors are DC so make sure that you connect it correctly or your grinder will run backwards.
Posted on May 30, 2009
  • 3 Answers
SOURCE: cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Posted on Mar 13, 2010
bcarson750
  • 5 Answers
SOURCE: coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Posted on May 16, 2010
How can i get manual for model 10903?
Do you mean the Bodum Bistro electric coffee grinder 10903? The instructions for use are available on the product page: http://www.bodum.com/us/en-us/shop/detail/10903-01US/ . Look on the right hand side of the page. The direct link to the manual is http://www.bodum.com/media/ifu/10903-01US.pdf . See page 4-5 (7-8 of the PDF) for the directions for grinding. The cleaning directions are on page 6 (page 9 of the PDF).
I hope this helps.
May 11, 2016 | Coffee Makers & Espresso Machines
How to fix a bodum bistro electric coffee grinder that doesn't grind well
This can be caused by several things;
If it used to be good but is now faulty it is most likely that it just needs cleaning. If you are using beans that are 'oily' they can clog the grinder, you should anyway disassemble it and clean every year. Do not use soap and water, just brush it with a stiff brush (e.g. the stiffest type of toothbrush) and a vacuum cleaner.
There is also a possibility that something has got into the grinder along with the coffee beans that has damaged the grinding wheels; in that case you need to replace the wheels.
Jul 29, 2014 | Bodum Bistro Electric Burr Grinder for...
Where can I find a replacement
https://www.baratza.com/cgi-bin/commerce.cgi?listcategories=action&parent=PART
Jun 12, 2014 | Bodum Antigua 5670/5671 Electric Burr...
Grinder does not grind coffee properly
sounds like the motor is loosing efficiency,,,I.E. motor going out.
Jan 13, 2014 | Bodum Antigua 5670/5671 Electric Burr...
Myu Bodum Bistro burr grinder calibration is off. How do I fix it?
Did you ever find a solution? I have the same grinder and it is off as well now after taking it apart.
Nov 11, 2012 | Coffee Makers & Espresso Machines
The Blade of my C mill coffe grinder has loosen. a complete day walking around my city and some several-hours-searches make me sure there's not aservice center for bodum in my country. in my city you can...
Bodum has several websites; pick the closest country here:
On the USA site there is a C-Mill available for $25.95 USD:
http://www.bodumusa.com/shop/line.asp?MD=1&GID=29&LID=310&CHK=&SLT=&mscssid=DEP02QHPXTQB9HGT2015H4DLF3A030Q5
Instructions are here:
http://www.bodumusa.com/shop/en/info04/pdf/05_5679IM_C_Mill_INS.pdf
There does not seem to be any replacement parts available or schematics. You might try contacting Bodum Customer Service as per the information on the countyr website closest to you.
Mar 19, 2011 | Bodum 's C-MILL electric blade coffee...
Am considering buying a Bodum Bistro grinder. Need to know if the burr grinder is conical and whether or not the inside cone can be removed for cleaning
It,s conical. It can be easely remowed for cleaning. Just take it easy so you know how to put the pieces back again. Its a very good priceworthy grinder. I still use mine after 15 years. But as it comes from the factory it will not grind fine enough for espresso. There are various methods and instructions on the internet how to tweak them to grind finer if you want that. Internally the mechanism looks very similar to the Solis and Dualit grinder. Since my grinder i quite old i dont know if my tweaks will work on more modern machines. But the basic construktion i still the same.
Jan 31, 2011 | Bodum Coffee Makers & Espresso Machines
Grinder is stuck in "on" mode.. Have tried to clear the hole but not working.
I have this problem also, has anyone worked out how to fix it yet. Thank you
Oct 04, 2010 | Bodum 's C-MILL electric blade coffee...
Coffee Makers & Espresso Machines Logo
234 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
