Question about Coffee Makers & Espresso Machines
What is the best method for cleaning the DGB-500 coffee maker system, i.e., vinegar/water combo?
SOURCE: Brewstation
There is a very fine screen on the outlet of the carafe that becomes plugged over time with fine coffee grounds. You can see it if you look down inside the pot above where the coffee comes out. Just using coffee pot cleaner won't clean it, because it's fine coffee grounds stuck in the screen, that are slowing the coffee going through it.
It's not easy to reach, so you'll a pair of needle nose pliers. Get ahold of the plastic ridge the runs across the top of it and it pops right out. You can use the bristles of an old toothbrush to scrub it. The bristles will fit in the spaces of the fine screen and force the deposits out. You can probably just leave the screen out altogether, it's just there to stop grounds.
Posted on Mar 08, 2008
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 19 Answers
SOURCE: slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
Posted on Aug 20, 2008
  • 8 Answers
SOURCE: algae in Braun coffee maker float tube
Use a mix of 50% laundry bleach and 50% water.
Half fill the tank and let it soak for several hours.
Rinse tank and refill with fresh water only.
NEVER RUN BLEACH THROUGH THE MACHINE.
Posted on Jun 24, 2009
Cuisinexpert
  • 61 Answers
SOURCE: DCC-1200 coffeemaker cleaning button flashes
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Posted on Aug 21, 2009
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
Can i clean my coffee maker with vinegar? if so, how?
Hi. Just like making a pot of coffee w/o the coffee. Run it through 3-4 times. Then run water through to rinse it out. 2 times.Good luck. Ron
Aug 27, 2010 | Cuisinart DGB-600 Coffee Maker
The coffee maker just quit midway through brewing this morning with half a resoviour of water left in it. I cleaned the screen at the bottom and determined there is no clog. Perhaps the heating element...
That has happened to me, and I ran a full 10 or 12 cups of vinegar and then 3 more times of water thru the coffee water resoviour and it took care of the problem. It is probably overdue for a cleaning.
Jan 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB-300
Definitely do the vinegar/water cleaning. It will almost undoubtedly resolve your issue.
Nov 22, 2008 | Cuisinart DGB-300 Coffee Maker
Water all over the place
the tube that attaches to the heating element is calcified inside. water cannot flow through it. i have the same problem and havetried vinegar solutions and even straightvinegar to loosen up the clog. no help so far. i am looking for a new heating element to fix it
Sep 10, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisnart DGB-500 shuts off before coffee brewing is complete.
I had the same problem. I ran it about 5 times with vinegar / water solution. A lot of hard water deposits (solids) showed up in the filter! The coffee maker now runs all the way to completion!
As a note, I live in an area with extremely hard water.
Apr 11, 2008 | Cuisinart DGB-500 Coffee Maker
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
