Question about AEG Dryers
Why does my aeg tumble dryer only heat up on the 30 minutes programming.
  • 74 Answers
SOURCE: Dryer tumbles but doesn't heat
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control." On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown --check and replace or reset. Be aware that a dryer may have two breakers or fuses: the motor will run when one works, but the heating element requires both. On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on. On an older dryer, make sure the pilot light is burning. If it isn't, re-light it. You can find directions HERE or in your owner's manual (pilot light instructions are often mounted next to the pilot light on the burner, too). Note: Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repair person.
Posted on Jan 18, 2006
protek480
  • 1714 Answers
SOURCE: dryer heats, then quits
The thermostat that controls the heat has failed. Try one of the other settings on the timer switch ans see if it will heat, the different cycles use different thermostats.
Posted on Jul 02, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
vostendorp
  • 347 Answers
SOURCE: Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Posted on Aug 13, 2010
ftw1952
  • 10319 Answers
SOURCE: AEG T57800 condensing tumble dryer.
The code E60 means low voltage. Theis means you can have dampness in the circuit which will hinder the voltage output or another problem in the breaker box such as the same. Moister will deduct the current flow in electrical lines as you may know.
Posted on Sep 11, 2010
Why does my aeg tumble dryer only heat up on the 30 minute program
Not familiar with that model, but if it only heats on a timed cycle, but not on a "dryness" cycle, I would suspect a defective moisture sensor.
Dec 27, 2016 | AEG Dryers
E60 code on Aeg lavertherm dryer understand it us
Yes the NTC or thermal cutoff failure can cause E60 error.
It may look something like this.
AEG Thermostat Thermal Limiter
For diagrams of your dryer refer this site.
AEG LAVATHERM 60750225500 Tumble Dryer Thermostat Spares Parts
Sep 20, 2014 | Dryers
Where is the filter on my aeg protex washer dryer
Tumble dryer Lavatherm T75280, 8kg
23988722-wycorcio5u0xxoh2plbhrodj-3-0.jpg 2. Open the filter
23988722-wycorcio5u0xxoh2plbhrodj-3-14.jpg 23988722-wycorcio5u0xxoh2plbhrodj-3-20.jpg Dado
Apr 03, 2014 | AEG T75280AC ProTex Condenser Tumble...
AEG Dryers e60
You have not specified the model of tumble dryer, so maybe some of the following fault codes not related to your appliance.
E61 - Insufficient heating (maximum time exceeded)
E62 - Power relay to heater unit faulty
E63 - Intervention of auto-reset thermostat on the heater unit.
E64 - Heater thermostat.
E65 - Fan motor triac faulty.
E66 - Fan motor thermal protection.
E67 - Triac control faulty.
Dado
Feb 23, 2014 | AEG Dryers
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Dec 21, 2010 | AEG T58840 Dryer Electric
I HAVE A AEG LAVATHERM 500 R TUMBLE DRYER 25 YRS OLD IT START RUNS ITS CYCLE BUT NO HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | AEG Dryers
New element fitted still only top hafe of element heating
heatman101
yuyu
Dec 17, 2008 | AEG T57800 Electric Dryer
Dryers Logo
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
