Question about Exercise & Fitness
Can you reset the Fitbit Zip backs to zero each day without syncing to the computer
How to reset fitbit time
  1. Log in to your fitbit.com dashboard and click the gear icon in the top right corner.
  2. Click Settings.
  3. Scroll to the bottom of the Personal Info page and modify your timezone.
  4. After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
Mar 13, 2017 | Exercise & Fitness
Steps do not reset at end of day
Try to perform a reset of the Fitbit. Follow
How do restart my tracker
When does my tracker reset and what happens to the previous day data
Your tracker resets your data to zero each night at midnight. For most trackers, your minute-to-minute data will be stored in your tracker for up to seven days without syncing. If you have a Fitbit Alta™ your minute-to-minute data is stored for up to five days. A daily summary of your activity is stored for up to 30 days.
Keep in mind that your calorie burn estimate will begin each night at midnight, so if you're up late and moving around, your tracker will adjust your calorie burn accordingly. Even if you are asleep at midnight, you will still see that you've burned some calories upon waking up in the morning. This is because you still burn calories even if you are sedentary or sleeping. Fitbit calculates your calorie burn based on information about your age, gender, height and weight.
Apr 16, 2016 | Fitbit Flex Wireless Activity Tracker...
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
How do I set the time on my fitbit?
After you charge it back up, you will need to sync your Fitbit, this Sync will update the steps
May 20, 2015 | Fitbit Zip Wireless Activity Tracker,...
My Charge Fitbit is not holding a charge. Yesterday it was dead within 1.5 hours. I have used the paperclip to try to reset without success. I am ready to throw in the towel so to speak.
You can put the software right, with a reset. Hardware errors and batteries won't change a bit when you use the reset button. When the battery is bad, and it looks that way, just return the Fitbit and ask for a new or new battery. It still should be under warranty. If the warranty is only 90 days for the battery, never again buy a Fitbit in the place you are living. In Europe electronics have a warranty of 24 months.
Apr 19, 2015 | Fitbit Charge Wireless Activity Tracker...
How do I set the time on a Fitbit Zip?
  • The current time can be viewed on the Fitbit Ultra's display.
  • The time can be displayed in 12 hour format (e.g., 5:00 PM) or 24 hour format (e.g., 17:00). You can adjust this setting on the Edit Profile page, which affects the displayed time on the Fitbit Ultra, graphs, and input fields across the site.
  • The clock display can be disabled from the Fitbit Ultra setup screen.
Feb 15, 2015 | Fitbit Zip Wireless Activity Tracker...
How do I setup my fitbit force
Does your Force show up on the Dashboard?
If not then
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-set-up-my-Fitbit-tracker-on-a-computer/
If your having problems syncing then
http://help.fitbit.com/articles/en_US/Help_article/I-m-having-trouble-syncing-my-tracker-to-my-dashboard
Of course without knowing what you Sync through I can not be much help.
Dec 16, 2014 | Fitbit Force Wireless Activity Sleep...
How do i connect my fitbit device to my verizon tablet.
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
Sep 17, 2014 | Fitbit Ultra Tracker
Need help downloading a fitbit to my hp computer
  1. Go tohttp://www.fitbit.com/setup/and click theDownload Herebutton to download Fitbit Connect for your Force, Flex, One, or Zip tracker. If you have an Ultra, you should instead followthese steps.
  2. Once the download has completed, open the file and begin to follow the onscreen instructions.
    If you are on a Mac, open the dmg file. If it doesn't appear on your desktop, search for "Fitbit Connect" in Spotlight.
    If you are on a PC, run the .exe file from your download location. If it doesn't appear on your desktop, search for "Fitbit Connect" in the Start menu.
  3. Once the installation is complete, you will be presented with the Fitbit Connect Main Menu. SelectSet Up A New Fitbit Device.
  4. Account Setup:
    • SelectNew to Fitbitif you don't already have a Fitbit.com account.
    • SelectExisting Userto log in using your existing Fitbit.com account.
    • ou will be asked for a few details about yourself. This information improves the accuracy of your caloric burn and distance data. You can later adjust yourprivacy settingsto control which details are shared with others.
    • After filling out your personal information, you'll be asked which device you're setting up. Select the appropriate tracker to continue.
    • Plug the wireless USB sync dongle into your computer (this is the smaller USB device--not the charging cable), and bring your tracker near to it to begin pairing.
    • Tracker Pairing:
      • Force, One, or Zip: You will see a pairing number that appears on your tracker's display once your device has been located; enter this number on your computer.
      • Flex: Follow the onscreen instructions and rapidly tap the device when instructed, then confirm its vibration.
    • After clickingNext, your tracker will connect to your Fitbit.com account. This can take up to a minute.
    • Once your tracker has connected to Fitbit.com, you may be prompted to enter a greeting (depending on which tracker you have). This can be your name or any 8-character combination of letters or numbers.
    • When your tracker is linked with your Fitbit account, Fitbit Connect will notify you and present some basic instructions on using your device.
    • You can now log into your account dashboard to view your synced data.
      You will not need to repeat these steps once they have completed--you can simply login tohttp://fitbit.comto access your dashboard.Or Still having Problem Then follow Us For
      HP Support
Apr 24, 2014 | HP Office Equipment & Supplies
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
