Question about Microwave Ovens
What does error code H97 on microwave mean?
Cannot start microwave
  • Microwave Ovens Master
  • 9,085 Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In the US, you can get support or find an authorized Panasonic servicer here.
In Canada, you can get support or find an authorized Panasonic servicer here.
If you have other questions, please e-mail me here with your full model number as shown on the tag in or on the oven, and your detailed symptoms.
Posted on Dec 28, 2016
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
What does H97 mean?
It is an error code that means ether the magnetron or the inverter is bad.
Oct 16, 2014 | Panasonic NN-SD372S 0.8 cuft 950-Watt...
My Microsoft says H97 and won't start running and goes back to H97.
The "H97" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and Panasonic customer service to find the proper part for the microwave.
Oct 05, 2011 | Panasonic Microwave Ovens
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
H97 error code and excessive heat
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Sep 12, 2009 | Panasonic Microwave Ovens
Panasonic microwave oven error code H97
Oct 09, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
