Question about PRINTER Office Equipment & Supplies
Pro 9000 printer flashing orange and green 10 times pauses and repeats
  • 45 Answers
SOURCE: Sony Wega KP-FW46 - Standby Flashing 10 Times
Remotes can be ordered from various websites, I would check ebay, sony, those type of websites. The standby light flashing means your bulb on the TV needs to be replaced.
Good luck.
Posted on Mar 31, 2008
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
jonniewalker
  • 1029 Answers
SOURCE: flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Posted on Mar 31, 2009
JackHeath
  • 1049 Answers
SOURCE: Pixma 4500
12 times is listed an AP position error:
Carefully slide and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaner squeegie on the printhead. This mechanism is probably stuck at its full extention rather than being back at home base. Every time you turn it on and off you should see it try to move but it will seem to be stuck. Give it a little assistance and that should release it. It can get glued up with drying ink. The mechanism that drives the sliding squeegee relies on a spring for it to return and the spring isn't strong, so the whole thing jams up...
which is probably what the code means - jammed mechanism.
Posted on Mar 08, 2010
  • 129 Answers
SOURCE: TV will not come on, LED light flashes 10 times,
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Posted on Jul 28, 2010
All the ink tanks are not lite up. I was in the middle of a large print and before I put the first ink tank it did not light none of the ink tanks were lite.
There are a couple of possible problems.
1 A faulty printhead
2 Faulty or empty ink cartridges
3 The contact pins in the printhead could be dirty, covered, or sitting in a pool of water/ink generating a short-circuit.
Check all the cartridges have ink visible in the rear ink chamber, check the contact pins are clean and dry, make sure the chips on the cartridges are clean and dry. If all those are OK count the number of orange flashes the machine shows in a repeating sequence. 10 sequential flashes often indicates a trashed print head.
Jun 25, 2015 | Canon Pixma Pro 9000 MARK II InkJet Photo...
When I turn my mp230 it just flashes the Green on buttom and goes back in forth with the orange triangle for 22 times and then it pauses in the Green light for a few seconds and it repeats itself
The purpose of writing this letter is to inform you that my machine got some technical problem.
We unable to solve this problem since last year.My machine is Konica R1 DP-1000E. And the machine always show the words "The machine error printer no: err-D1301-0 link with processor failed." We are here request for your technical help
If possible, please contact my cellphone +673 8896003.
Aug 02, 2013 | Canon PIXMA MP230 Multifunction color...
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    I get a series of blinking orange lights and a green pause.
    Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
    Jul 14, 2009 | Canon i850 InkJet Photo Printer
    6 orange and 1 green flashing light on S400 canon bubblejet
    Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
    Apr 09, 2009 | Office Equipment & Supplies
    Orange alarm light flashing
    reset your printer with this instructions. (find the similar printer)
    Mar 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA iP1000 Printer - don't work
    GO ON LINE
    CANON PIXMA iP1000 7 FLASHING LIGHTS
    ENTER
    ROD
    Feb 04, 2009 | Canon Office Equipment & Supplies
    Canon i550 printer stoipped printing
    My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
    Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
    Need help with S-400 Canon
    How many times from pause to pause?
    May 13, 2007 | Canon S400 InkJet Printer
    Top PRINTER Office Equipment & Supplies Experts
    Gene
    Hardeepak Bhambh
    Hardeepak Bhambh
    Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
