Question about Roku Televison & Video
On my neat gear Roko box the picture is froze can not turn offf have unplugged no help
The picture on Netflix is froze can't turn it off I unplugged it then that did'nt help
Try turning off WD tv or any device that you play Netflix through. Turning off the TV alone will not solve the problem.
Dec 23, 2016 | Netflix
How do I enter my code foe roko on my t.v.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 17, 2014 | Televison & Video
I'm getting this message "The operation could not be completed. No other information is available about the problem." I had a paper jam..fixed it and now it won't scan anything without that er
1. Quit neat app.
2. Turn off scanner.
3. Unplug scanner from computer and outlet.
4. Wait a minute.
5. Plug scanner into outlet and computer.
6. Start Neat app.
Hope this helped.
Feb 21, 2013 | Neat Company NeatDesk Scanner for Mac
It will not shift to parking
Need to check for the linkages, a possible play in them due to wear offf can make it tight on the gear box levers. So this alignment could have changed. Need to check from the in dash hand lever to the gear box visually to see the play and correct. If not the fault can be in the gear box= getting tight.
Sep 20, 2010 | 2007 Toyota Camry
I have a thomson sky plus box, the picture froze and i could not perform any functions at all. i unplugged it from the socket for 2 minutes and switched it back on. only the standby light comes on but it...
unplug and hold backup button box plug in wait for all 4 led to light release button box will take 20 mins to update if this doesnt work needs caps in psu replacing
Aug 17, 2010 | Televison & Video
Bush hd freesat topbox will not switch off or operate. plugged in hdmi cable to box and television, switched on box started software update, after a while screen went blank since then nothing on screen and...
blobby 1589, my Bush freesat box has just done the same. Power going to it. Blue light on. Cannnot turn the box on. Screen froze before it turned off. Tried unplugging it. There was a software upgrade 2 days ago - wonder if that has anything to do with it
Mar 06, 2010 | Audio Players & Recorders
Fridigaire side by side ice maker not dispensing
I just fixed my daughter's frig with the same problem. The gear of both the box and the ice holder got water in the gear box and froze. This did not allow the gears to mesh and turn the auger. Clean the ice from both sides of the gears and try it. Works great now.
Rick
Jan 31, 2009 | Refrigerators
Televison & Video Logo
27 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
