Question about Water Dispensing & Filtration
My kinetico water softener isn't using any salt . The only time it cycles is when I do it manually.
IFIXALL
  • 868 Answers
SOURCE: Tablet salt
No unless you can find that tests were made and confirm that it is safe .
Posted on May 23, 2008
IFIXALL
  • 868 Answers
SOURCE: dishwasher - water softener not working
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
Posted on May 26, 2008
  • 5 Answers
SOURCE: salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Posted on Jul 28, 2009
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
  • 569 Answers
SOURCE: Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Posted on Feb 21, 2010
Testimonial: "Thank you so much. My husband is quite handy but never having dealt with water softener we were looking for some advice. We certainly appreciate it!"
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
Aqua Systems water softener isn't using salt when it regenerates. Water isn't being softened. Have manually regenerated three times -- goes through the cycle but water seems to be unchanged. Any troub
check that the small hose to the pickup in the salt tank is not blocked or loose allowing air into the unit rather than the salt water. IT runs on a venturi effect so any air leaks will not allow the water to be picked up. Download the operating manual for the unit as it has a detailed operation including fault finding and over hauling of the unit.
Jul 02, 2014 | Water Dispensing & Filtration
Water Softener full of water, not draining, or using salt
How old is the system ? Where does the system drain to ? If this is the softener you have (seems awful large for a household) it is probably the injector/nozzle assembly. I have attached a manual to help you. A restriction in the drain line could also be the problem. Fleck 2850s
Mar 20, 2014 | Fleck 165,000 Grain Series 2850 Commercial...
Kenmore Water Softener does not advance through cycles
You can send to the company for repair too ! If it sill under warrenty to fix it and aslo don't try the step anymore it might cause some parts damage that the service provider my charge you more.
Dec 09, 2013 | Washing Machines
My water softener emptied im not sure how long it was empty for but I dont think it was too long I filled it with salt and now it doesnt work. It still regenerates but im getting hard water still any...
Do you mean the salt tank was empty? If so fill salt tank half way wait about 6 hrs for brine to develop. Manually regenerate softener 2x within 24 hrs. When the salt runs out the resin becomes saturated with hardness minerals. It takes at least 2 regeneration cycles back to back to completely restore soft water. Also the hot water will take some time to get soft. It will help to flush water heater after cold water is consistently soft.
I hope this helps,
h2oservices
Feb 26, 2011 | Culligan Compatible S7011C RS23SED5...
Cullihan water softener-No water in tank-Orange water in house-Salt level measured 3 months ago, has remained the same. ( no salt used ) Repair man claims to have fixed the timer 45 days ago.
the way a water softener is set by , goes off the hardness of the water and how much water you use. Doing a manual cycle will show you if its at least working or not. If nothing happens when you do a manual cycle then you should call back the repair man and have him look at again. The float might be stuck in the brine tank, you can try emptying the salt and cleaning the salt tank out side with a hose, spray water in to the float and make sure is clean and free . Add salt with 3 gallons of water and do a manual cycle. If this still doesn't work then it could be a stuck valve inside the water softener that is stuck closed.
May 18, 2010 | Plumbing
Where do i put the salt in my hotpoint dishwasher ?
If you don't put salt in the appliance then the regeneration crystals will clump together over time and solidify. This will cause a restriction in the softener unit.
If you stopped using it and then started again you may find that the impurities caught by the crystals have simply found their way into the appliance.
You can set the softener to be at minimum setting if you are in a soft water area.
The salt isn't used to soften the water, it's used to clean the crystals in the water softener unit.
Why Do I Need to Use Salt in my Dishwasher?
Salt is needed to ensure that your dishwasher's in-built water softener gives an optimum performance. You will especially need to use dishwasher specific salt if you live in a hard water area. You can purchase one of our Aqua test strips (part number 180876) to determine the hardness of your water from our parts and accessories store or call us on 08448 225 225 .
Manually drain the floor of the machine, put in salt, and check out.
open the salt container at the bottom, and it will be full up with water, and it really will smell bad. clean it and add salt near to 1kg. then run run a prewash cycle and then check out does the salt error is coming up.if yes then more salt needs to be added.
This will help. Thanks please keep updated. please do rate the solution positively.thank you for using fixya
Mar 17, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
We have a fairly new Kenmore Elite front loading washing machine. We also have rather hard water here in Indiana. Problem is, water softeners do not seem to work. The manual says that the liquid water...
Hello, I would like to help with your dilemma. First, adding a Liquid or Powder Softening agent to the Wash or Rinse Cycle of a Washing Machine when using extremely Hard Water as the source is trying to treat the symptom and not fix the cause. These pre-packaged Softening agents are filled with Salts that attempt to mix with the Hard Water Minerals and Neutralize them so the soaps can saturate the water and supposedly clean the clothes more effectively. However, the Hard Water Minerals are still trapped in the water supply with these Salts because they are not removed. And, the manufacturers of these Salt Based Softening Agents have no idea of what level of Hardness (Calcium and Magnesium Carbonates) exist from City to City, State to State, or in private Well water supplies. So, if they provide 200 parts per million of Salts in their package, but the Water Hardness is 600 parts per million of Calcium and Magnesium Carbonates, there is no way the Salts will be effective. With "Traditional" Whole House Water Softening, the Water Treatment Appliance actually removes the Hard Water Minerals before the water is distributed to the entire home or business, then allowing the Washing Machine, Dishwasher, Water Heater, Showers, Bathtubs, and other water bearing appliances to perform their tasks as specified by their manufacturer. These Water Softeners typically attach to the main water line of the entire home or business, and virtually exchange equal amounts of Salt for equal amounts of Hardness regardless of the incoming hardness rating. Then, as the total capacity of the Softener becomes exhausted for the batch of water it has treated, the Control Valve automatically Regenerates the system with a new batch of Salt-Softened Water to use in the home or business. And, when you treat the water for the entire home, you reap the benefits of Protecting ALL of the Plumbing, Fixtures, Faucets, Valves, Appliances, and other household items from Scale and Hard Water Destruction. Visit our Web Site for more information: www.puresafe.com Thanks and Hope this helps. Victor Kernes
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
Salt for DDW1805 Danby
Jul 12, 2008 | Danby DDW1805W Designer Series...
Water Dispensing & Filtration Logo
1,220 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
