Question about Cell Phones
Bought this unit, Hook 5, on line right before Christmas. Installed it yesterday and found out the included micro card does not fit into unit. Why would they include a card that would not fit?????
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:
  2. To set it as a ringtone, send it as an attachments to you It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
SOURCE: my 8g micro SD card only finds 104kb of memory
The Samsung Gravity doesn't support the Micro SD HC (High Capacity) cards, just the regular Micro SD cards. Yes, it sucks.
Posted on Mar 16, 2009
  • 56 Answers
SOURCE: R4 card not recognised in DS lite
which r4 card is it? r4,r4sdhc,r4sdhc upgrade or the r4i.
Posted on Jul 04, 2009
  • 60 Answers
SOURCE: Vertical red lines apear on Sony XBR after Roku install
try re-botting your HDbox,also refit your scart lead to your box & t.v.
If you drop me an e-mail I will go through how to re-bot your box,if you don't know - re-botting your box helps pull in all the new software for your box - think it like a pc needing to update the programmes.
Posted on Aug 07, 2009
  • 1891 Answers
SOURCE: Range replacement switch installation ???
sounds like you have the wrong sw . do not install . ck the old # and see it this is a proper replacement . / I did look your sw and it has a blue housing and muilti break of shaft . it should replace a standard sw but not the dual element . re ck where you purchase to make sure is the right one .. mm
Posted on Dec 08, 2009
Install music on this android
Most have micro or mini SD cards, check which you need in the manual. Once the largest card you can afford/fit is installed, hook up the phone to your computer via the USB lead and copy the music from your computer to the sounds or music folder in the SD card memory
Oct 14, 2014 | Cell Phones
How do I find out if the lead and plug on my jovia coffe maker which is red and I only bought yesterday is right as the coffee maker is black
plug it in and see if it fits ,if it fits them should be OK ,lead color is not relevant ,probably got lead from red unit ,or leads are meant to be different color to unit ,only cosmetic
Sep 14, 2014 | DeLonghi Nescafe Dolce Gusto Genio...
What type/size memory card does it use? I have bought this camera but cant find the type of memory card device that fits. All that is in the market does not fit. Please give the serial number of the...
It use micro SD card or micro SDHC. You can use also Transflash (TF) with SD adapter.
Please don't use other cards. Be carefully while inserted the card, do it by right orientation.
Jul 31, 2011 | Olympus FE-46 Digital Camera
Micro ATX motherboard ATX case?
Two possible causes - either you have installed it badly and it shorts to the case (take it out of the case and try it there) or not all the necessary cables were connected (check especially the power cables and the power button).
Jul 13, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
Recently bought a micro sd card for my black jack and when I insert it and open storage card folder on phone it says not found
ok first the micro sd card cannot exceed 4gb or the phone will not recognize it, if that is not the problem then you will have to format the card on your pc go to computer and right click on the card and select format then place back in phone. hope this information was helpful:)
Nov 03, 2009 | Samsung BlackJack II Smartphone
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Lg kp 500 wont recognise sandisk micro sd!!! aghhhhh!!!
Some memory card wont be recognized by some phones or pc's. I also bought a sandisk card before and just found out (through reading online forums) that some don't actually work.
Feb 22, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My kodak m1063 ask for a sd4g, the one i bought was too small in
This camera takes a differnt memory card then the common SD CARD! Wal-mart will have the right card for you or most other stores that sell cameras!That should eix ya right up!
(Please use the ratings ! To keep this site FREE!)
Dec 14, 2008 | Cameras
How do I get songs on my micro SD card?
the small card fits in to the biggerones to transfer files from your phone to your computer or a photo station.( like at walmart) where you insert the card and print photos. AS to getting music on it i have found the easiest way is once installed in your phone go to i tunes and down load them. or you can search songs on yahoo mobile as mp3 and save them to the card as well.
Dec 11, 2008 | Samsung SGH-D600 Cellular Phone
I had a new sears heating unit installed by sears contractors yesterday. Before I purchased the boiler, I was told by sears salesman that I had a maintenance plan that included 24/7 repairs. 6 hours after...
Yes as with all big companies problems with comunications are a pain to say the least. Anyway it sounds like someone left a loose fitting. If you can locate the place where it is leaking there is probably a fitting loose there which you can tighten up with a couple of wrenches.
Sep 27, 2008 | Heating & Cooling
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
