How to activate colour registration - Office Equipment & Supplies
Colour shifting error p21
color registration patterns not read correctly by sensors
Mar 18, 2014 | Konica Minolta bizhub C250 All-In-One...
Registration code
WinZip is a file compression utility that allows users to "zip" files into archives that have significantly smaller file sizes than the original files.
If you purchase WinZip directly from the WinZip website, a registration code is sent to you via email that allows the software to be used as soon as it is installed.
If you purchased the program from a third-party retailer, however, you must use an activation code to activate and register the software. Launch the WinZip program.
A screen will appear, reminding you to register your product and giving you the option to enter your name and registration information.
Enter your name where prompted.
Enter the activation code that came with your WinZip installation disc or in the activation information email you received when you purchased the product.
Click the "Register" button.
Enter all required information when the WinZip Activation Information screen appears.
This screen collects the information that WinZip Computing needs to properly register and activate your software.
Click the "OK" button to submit your information.
The WinZip software will transmit your information to WinZip Computing's activation server, registering your software with the company and receiving a registration number that it will use to activate your copy of WinZip.
Check the email address you entered when activating your copy of WinZip.
A copy of the registration information will be sent to you, including the registration number that was used to activate your software.
If you need to reinstall WinZip in the future, use the registration number instead of the activation code.
or use freeware
ZipGenius is a FREEWARE product
http://www.zipgenius.com/index.php?id=33
ZipGenius can handle more than .zip or .rar file
20 compressed archive types.
http://securezip-express-for-windows.soft32.com/
Free zip
http://www.all-freeware.com/details/154438/1-click-unzip-.html
http://en.softonic.com/s/winzip-8-freeware
Sep 26, 2013 | WinZip 12.0 - Windows for PC
I need an activation code for zesuimshop.net Mobile pdf. Application code: 0093025 registraition code: 548017 I'd really apreciate your help, my email: lindokuhlenzama4@gmail.com
Please send me pdf activation code application code-0093026 andregistration number a9fe17 send my mob number 7600370743
Aug 17, 2013 | Cell Phones
Cannot re-register Vertus Fluid Mask software, which I already own
Hi aaliceronm,
Please follow the instructions below on how to register/activate your Vertus Fluid Mask software.
Vertus Tech provides two ways of registration/activation:
Fluid Mask 2.0: In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three months).
Fluid Mask 3.0: For Fluid Mask 3 they offer two ways of registration and activation of your full Fluid Mask license:
Online registration:
This option requires an active internet connection on the machine on which you are installing Fluid Mask.
1. If you already installed the trial version of Fluid Mask please open Fluid Mask and go to > Help > Register.
2. Fill out the registration form and insert your serial key. The serial key should have been sent to after you placed your order for Fluid Mask 3 and has the format
01AXYZB0B123F123CDA7121234567AF123
Please make sure you copy/paste the serial key into the serial key field to avoid typos or mixing up digits and letters like 0 and O etc.
3. Click on the button to send the information.
4. The registration takes a few seconds. If it was successful you will see a pop-up window confirming that you are now registered.
5. You can either copy and paste your information from there into a file or to create an e-mail.
6. In addition you can see the message "You have a full license" when going to > Help > About Fluid Mask.
Registration by e-mail:
3. Click on the button to send the information. The registration takes a few seconds.
4. If Fluid Mask cannot detect an active internet connection or could not complete the registration for other technical reasons, then Fluid Mask will display your registration information in a new window.
6. Please send the complete information displayed to registration@vertustech.com. It is important that the information we receive is complete and correct.
They will process your registration as soon as possible and provide you with a license code by e-mail. You can then use this license code to activate your full Fluid Mask license under > Help > Register in Fluid Mask 3.
^return to top
Do I need an active internet connection?
Fluid Mask 2.0:
In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three month).
Fluid Mask 3:
Fluid Mask 3 does offer an online activation. For those users who don't want to connect their workstation where Fluid Mask is installed to the internet we offer an activation by e-mail, too. Instructions are displayed in the software during the registration process.
Hope it helps.
Thank you for using FixYa.
Jun 30, 2011 | Computers & Internet
Colours are blurry
Registration problem, the color are not on top of each other looking blurrry. Service mode has a Regristration test that is run and can check registration
Jul 29, 2009 | Konica Minolta Office Equipment & Supplies
Registration activation code for winzip
Winzip v9.0 Name - Cool Guy - Serial - B93E0A81
Jun 24, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
For registration of pvplayer.3.4
You have to contact the Vendor/Site who sold you this Software and they'll provide you with the Activation Key.
Jul 01, 2008 | Nokia 7610
Register Problem
It needs a service call to do the color registration adjustments.
Dec 05, 2007 | Xerox DocuColor 12 Color Copier
Colour and black and white
Colors registration need to be adjusted. It's a long procedure to describe. But if you are close to PA or NJ PhillyCopiers.com can do it for you.
Sep 17, 2007 | Ricoh Aficio AP3800C Laser Printer
24 people viewed this question
k24674
jasbo
jasbo
