My microphone is going lose how to tight - Audio Players & Recorders
2006 isuzu nqr replace pass side caliber,pads ,and rotor I go to bleed the system no pressure at the pedal I true a vac pump to bleed still no pressuse I need help
What you need to do:
-Make sure the brake recevoir is full of brake fluid.
-Start the car and let it run and you need to pump the several time
untill you get presure.
-Lose and barely tight it back the bleeder bolt at the side that you just replace. (lose Only. Do not open!)
-Use a Clear hose that fit to the bleeder bolt about 12" to 15". Connect it from the bleeder bolt to a glass jar or botle.
-Ask a helper to press and hold, then you lose the bleeder to let
fluid an d air come out. Then tight it back before release the brake pedal. (Over and Over untill you see no buble in the hose line)
- Make sure brake fluid is full don't let it run out.
-Now tight the bolt in place you should be good to go.
Mai Lor
Feb 22, 2013 | Cars & Trucks
My power switch on the handheld microphone is on red all of the time and the microphone is not working
Loosen the top assembly of the mic and see if problem is solved.If not , try to pull out the electronics board now connect the battery and activate the switch. If everything is alright your problem is caused by tight plastic enclosure which does'nt allow free movement of the on and off switch.
Sep 12, 2012 | Gemini Sound Products Vhf1001M Microphone
Battery keep losing from the connection ?
Send the mic to Shure for repairs.
Apr 21, 2012 | Shure SM58 Professional Microphone
Microphone won't turn on
When you say "turn on" the SM58 does not normally have an on/off switch on the mike. Does yours? If so, bypass the switch. Did you try different cables or another mike on this one's cable? The SM58 is a very rugged mike but can be damaged. I'd make sure all cables, connectors, and such are good before suspecting the mike itself.
Oct 26, 2010 | Shure SM58 Professional Microphone
Losing sound when plug in mic
You are probably plugging the mic in the wrong port, you should plug it in the other port looks the same.
I think the port that you are plugging in your mic is of sound (headphones).
Hope this helps
Mar 30, 2010 | Audio Players & Recorders
I have a Satellite M35X-S114 that has a mic problem. I was using Skype with no problem and then it just stopped working. I hear through the speakers and headset but no mic. I also tried a new headset with...
Sometimes programs like Skype will lose the Mic settings and chose another input channel. Check your operating system's audio settings under something similar to "Recording" and see if microphone is checkboxed and turned up. Also, make sure it is not muted on Skype and/or the operating system.
If you have Windows XP, for example, look for the audio settings icon (little speaker) just left of clock area. Open and go to "options". Choose "properties" then "Recording". Look that your microphone is "Selected" with a checkbox and is turned up. To hear yourself during this, you will need to go back and choose "Playback" instead of "Recording" and de-select "mute" (if checked) for microphone and turn it up to see if you hear yourself talking over the speakers/headphones.
Also, check the Skype settings for microphone and that Skype has the correct sound device selected for input - being your microphone and not another device.
Also make sure that there is not a manual, physical volume adjustment for the microphone on the laptop case itself. Could even be a mute button.
Oct 16, 2009 | Toshiba Computers & Internet
Sound keeps going on and off
If you lose sound after restarting the software or the computer, then it may be a problem with camera software or audio drivers.
Reinstall sound drivers and then camera software.
If sound goes on and off erratically while you use the camera, then it is probably a cable problem.
Check microphone cable.
If mic is camera built in, then check camera USB cable.
Use windows recorder (in Start menu/All programs/Accessories) to test the microphone and find out if problems depends on microphone on camera software.
Aug 28, 2009 | Computers & Internet
Karaoke microphone and wireless mic
Cord rolling might generally cause damage to the internal wiring.the only possible repair option is change the wire inside.A suggestion is to try not to wrap the cord tightly with the microphone.fold it separately and use a band to hold it.
Dec 10, 2008 | LeadSinger LS-3222 Consumer Microphone
41 people viewed this question
