Question about Dryers
Noisey rubbing noise when drum turning... - Dryers
2 Suggested Answers
  • 8404 Answers
SOURCE: Drum seems to be rubbing and making noise when turning
the drum does rub ... generally, there is no front or back to a drum. It rides on the rim on the back and on a smaller rim on the door. I normally find a felt "bearing" at these locations. and sometimes, there are wheels at the back on the bottom. Gravity and the drive belt make it work.
I hope this helps you
a
Posted on Sep 23, 2009
Hoover 750 lc heavy duty macking noise whene spinning dry
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
Sep 13, 2014 | Hoover Washing Machines
When machine went into spin it was very noisey and the metal tub has rubbed agaisnt the plastic inside and caused A bit of damage were it rubbed but the rubber seal was not touched I have taken the back...
It sounds like the bearings have collapsed..You may have noticed a noisy spin cycle prior to loosness in the inner drum...This is a big job. Get quotes...Good luck...Nomess
May 20, 2010 | Washing Machines
Dryer making noise when turned on
you have to specify what make your dryer is to be able to answer question
Feb 06, 2010 | Dryers
Dryer very noisey when drum turning
This problem is normally cause by the drum rollers having flat spots on them and or needing lubricant or replacement.
Sep 26, 2009 | Maytag PYE2300AY Electric Dryer
Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Won't aggitate
If you get someone quite strong to heave on the drum and it makes a cracking noise then turns a little you will find that the Drum bearings have seized , must have been fairly noisey before it gave up.
Outside chance that the motor has seized
Take the back off and peel the belt off the main pulley one or the other should turn
Jun 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
29 people viewed this question
Top Dryers Experts
