Question about Exercise & Fitness
When first starting the treadmill it has a mind of its own. It will start off normally but without warning it will speed up then slow down and have even did a complete stop.
  • 6,694 Answers
If you wish to get some details about treadmill repair; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 27, 2016
  • 175 Answers
SOURCE: Treadmill slows down and stops
hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
  • 16 Answers
SOURCE: treadmill goes normal speed until I get on it and
When was the last time you placed the correct lubrication between the walk belt and the walk board. This is a very common issue. Make sure you DO NOT use anything from an aerosol can. The acetone will cause the belt to get dry, hard and crack.
Good luck.
Posted on Jun 29, 2009
  • 95 Answers
SOURCE: Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Posted on Aug 01, 2009
buffalonyman
  • 1865 Answers
SOURCE: Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Posted on Aug 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
Posted on Jun 01, 2010
How can I slow down a Sportcraft TX 320 treadmill?
Hi There, hmmm.... am I hearing that the treadmill starts too fast? At over 1mph? Most US treads will start at 1MPH and some will allow selection of .5MPH in the maintenance mode settings maybe. Otherwise, this could be attacked by a technical crew, like jatinah electronics possibly. If the treadmill would be set at one speed only that could be accomplished by reducing the drive signal at the component-level. It is certainly workable, but I would need to know what the current speed is that is too fast for her, and her ideal speed. ;o)
Jan 15, 2015 | Sportcraft Exercise & Fitness
When i start my proform 750 it doesnt slow down. It goes straight to max speed and never slows down.
try to calibrate the speed on the treadmill look in the trouble shooting section of the manual
Nov 04, 2014 | Proform 750cs Front Roller Model 299560
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Carol lewis mot566 error code 03
1)probably a faulty speed sensor
2) speed sensor is not plugged in properly.
3)possibly a faulty motor
4) Main control board or lower board.
The error codes will differ between makes and models but could be e1.
Check this video for speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
adjust the speed sensor:Move the motor to slacken the pulley, then lift the motor to get underneath. That is where the treadmills speed sensor will be located. It is usually a square or rectangular shaped green module with connectors at both ends.
Finally after you did the adjustment you can conclude:
A) Faulty Speed sensor B) Main Motor faulty C) Main Motor Controller faulty.
attached block diagram for treadmill that I did for any treadmills,see how the Main Motor Board has function for 90% of the treadmills.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 23, 2011 | Exercise & Fitness
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a model 297980 J8 proform treadmill. when I first start it up without the safety key in it, the treadmill runs at full speed for about 2 minuets. After that it slows down and stops. The speed is set...
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
May 01, 2010 | Proform Exercise & Fitness
My treadmill goes at a normal speed when no one is on it. However, As soon as I start walking it slows.
This is normal operation due to putting weight on the belt. Set your final desired speed after you start walking.
Jun 16, 2009 | Weslo Cadence CT 4.8 Treadmill
My treadmill will go normal speed set at until you start walking on it and then it slow way down. Why would it do that?
Try looking for a problem in the power.if that doesnt work,send it to a technician or if you had a warranty on it even better.
Jun 15, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
