Question about Watts Electronics - Others
Hoe do I charge my motomaster eliminator power box 700 watts
3 Suggested Answers
  • 5603 Answers
SOURCE: I have a motormaster eliminator powe box 1200
Look on this site and see if yoou can find one with:
Correct dimensions
Correct voltage
Correct terminal connections
Don't worry if capacity is a few more amp hours. Some batteries have improved the capacity.
Use your measuring tape for size.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=393246&k=battery%20sealed
Posted on Oct 23, 2009
caroldon
  • 17130 Answers
SOURCE: cyberpower 1000 watt 12 volt
When the wattage of an invertor is specified it is meant for the power load but with a gradual CURRENT drain. If you load with modest loads of lighting , fan or other low wattage device it will work without tripping off. In this case your microwave when loaded will initially start up with a large surge current requirement thereby shutting off the invertor as it detects overload. So the safe limit to operate a microwave is to have an invertor above 2000 watts . If the input supply is 24 volts , then it will be more powerful.
Also try with a low wattage/heating setting on the microwave, tighten the battery terminals of the battery . Sometimes it might start but can also damage the invertor. failure of the driver MOSFETS.
Posted on Jul 12, 2011
Why doesn't it charge?
Carolyn, These power boxes were not made to last, the batteries inside are probably bad now, if still under any warranty return for exchange or hopefully refund.
Feb 09, 2016 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 2 in 1 spotlight/lantern power
I am looking for a charging cord...I moved and haven't seen it in a while. Is there somewhere i could buy one.
Dec 02, 2013 | Eliminator MotoMaster Mobile Power...
My motormaster eliminator mobile power pack 700A just started beeping. What is wrong with it?
if there is a car fuse, under the cover, remove it.
most of the time, it is only use to activate the LOW Battery alarm.
Put the fuse back, when fully charge.
Jul 10, 2011 | Eliminator MotoMaster Mobile Power...
Have an eliminator intelligent battery charger model CT-1200A 11-1513-8. Can this be used to keep a car battery charged for a period of say 3 months while car is not being used. I have this same question...
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Nov 27, 2010 | Eliminator MotoMaster Mobile Power...
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Electronics - Others Logo
112 people viewed this question
Top Watts Electronics - Others Experts
David Tickner
Brett Duxbury
Brett Duxbury
Alden Tiefenbach
Alden Tiefenbach
Level 1 Expert
Are you a Watts Electronics - Other Expert? Answer questions, earn points and help others
