Question about Cameras
To buy lcd display Y82903 V03 digital FPC PBH 1320
I have a Sony A300. When I turn on the live view screen, I only see a bunch of vertical lines on the screen and cannot see anything that I try to display (ie. menu, display, prior photo's, or the...
Sorry to say your LCD screen is cracked, it happens a lot with the Sony DSLR-A300 and A350. The solution is to remove the cracked LCD and replace it with a new one. The repair isn't that difficult, but you have to be careful removing the LCD or you will break a latch holds two FPC cables together and then will have to replace yet another part that takes MUCH more labor.
I did a Google search for "sony a300 lcd repair" and at #2 I saw an online digital camera repair shop that has done tons of this repair over the last few years.
Hope this helps!
Thomas Drayton
Owner, Digital Camera Repair
Jul 11, 2011 | Sony Alpha DSLR-A330 Digital Camera
Meggita, where did you get the internal flex wire to fix your Sony SR42 screen?
I know the SR42 FPC for the LCD is the same as the SR200, and we have both listed in our store for $20 incl shipping.
Hope this helps!
Thomas Drayton
Jul 11, 2011 | Cameras
Camara Nikon D60 - error: pulse de nuevo el disparador
Hola,ha recibido alguna caida o golpe en el lado inferior izquierdo junto al display?
Si asi fue tiene el conector FPC cortado.
Otro la mas frecuente debe de reemplazar la unidad de secuencia SQ base plate unit.
Feb 19, 2011 | Nikon D60 Digital Camera
My lcd on my DCR-HC42 is not working totally but i can use the view finder in capturing photos and videos....whats wrong with the LCD?do i have to bring it to a repair center?
it is simble try to open ur camer and remove ur lcd there is a connector that connecting lcd and bord that called lcd fpc chaing that strip it will work
Jul 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD panel is black of my dcr hc21. I have to change the LCD panel for a new one? Whats the price of the LCD panel?
r u sure that ur lcd pannel damage most proberly goning that lsd fpc u just conform that first because that fpc is very cheap
Jul 07, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Can't see anything in LCS display
problem on ur lcd fpc that connecting camera to lcd that u want to chaing .if u cant chaing try to contact me my no.00971503853766 in u.a.e i have a service center
Jul 04, 2009 | Sony DCR-HC30E MiniDV Camcorder
Sony dcr-hc21e camcorder lcd stop working,viewfinder is ok?how to remove casing of this device.thanks
This problem can fix by replacing the flexfoil or FPC between the camera and LCD assy if you need parts call a Sony repair service center or ask us
Rob Rotronica
Apr 15, 2009 | Cameras
Sony DCRHC 42E handy cam LCD problem
problem on ur l.c.d strip (lcd fpc ) u chaing this one
Sep 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Regarding Error #45
Well Heero if you are the tech guy you say you are- and Kodak arn't helping you- this suggests a mainboard failure and the camera is not going to get repaired.
Jun 05, 2007 | Kodak EasyShare LS443 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
