Question about Cell Phones
How to hard reset cord in x287 micromax - Cell Phones
I forget my password how to reset model Micromax x267
instructions are here Anthony. You resurrected a post from 2014!
Info will be the same for your phone as the X287.
MICROMAX X287 How to Hard Reset my phone HardReset info
Jul 11, 2014 | Cell Phones
Micromax x287 privacy protection lock hand flash
Micromax x287 private protection code
Jan 06, 2014 | Cell Phones
Cant pass smog my hc levels are to high
High HC means there is unburned fuel going out the exhaust pipe.
The fuel mixture is too rich or the plugs are not firing properly.
A mechanic would check for a rich fuel mixture first.
Jan 05, 2014 | 1987 Oldsmobile Cutlass Supreme
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
Micromax X287 reset password .......
micromax x287 privacy protection lock hand flash
Oct 26, 2013 | Cell Phones
I have a micromax x287 mobile. i change his password and lost the password. please tell me how to reset my phone?
i have forgotten my password of micromax x287. i had chnage my password and forgotten plzz help me out
Oct 16, 2013 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
I have micromax x287.I want private protection unlock code
i have micromax x 287 mobile
But file manager open then show me input password
i have no idea old password
pls give me solution
Aug 09, 2013 | Cell Phones
How to remove password of privacy protection in mobile of micromax x287
How to remove password of privacy protection in mobile of micromax x098
May 05, 2013 | Cell Phones
I forget my security privacy lock password for message of samsung SGH- Z240 mobile phone. What is the default password or lock code to access in security privacy lock of message?
Hello s_a_rocky,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
Jan 15, 2009 | Samsung SGH-e315
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
