Load bearing noise when spinning. - Washing Machines
  • 59 Answers
If you have a front loader washing machine, the rear bearing can go bad a make a loud noise when spinning. The only way to fix it is to remove the basket and replace the bearing. Depending on how old the machine is + how much money to repair = new washer.
Posted on Dec 28, 2016
I have a admiral washing maching, model LNC6766B71, it is top load. It makes a load noise in spin mode.
if noise is constant maybe bearings? Is the load even? Not totally familiar with item but the I think the two possibilities above are worth considering. Do an spin on empty. NOISE??? I would guess bearings.
Jan 02, 2016 | Admiral Washing Machines
Grinding/whining noise from gearbox/final drive - fiat 500C Lounge - 2010 model
I think removes the tyre both then check its gear box bearing noise or clutch plate bearing noise
Dec 16, 2013 | Cars & Trucks
Why does my washer make noise before the spin cycle
Depending on what the noise sounds like, these front load washers have rear bearing issues. The drum bearing is just not strong enough to support the weight and the larger the drum the more weight and I doubt they use larger bearings for more cubic feet machines. They need a buddy bearing or some sort of support to take all the weight off the rear bearing.
Nov 19, 2013 | Kenmore HE2 Plus Front Load Washer
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Load spinning noise
If you mean it is noisy when spinning, then could be main drum bearings are going.
If you spin the drum by hand from the front, there should be little or no noise.
If it feels rough or is rumbling, then it is definately the bearings.
It is not clear what you mean exactly.
Hope this helps.
Feb 02, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Noise in the spin mode on a Amana LWA50AW top load washer
Based on your description, it sounds as if your outer spin bearing is faulty. See link below for an illustration of the bearing. Special tools are required to replace this item.
Illustration provided by; www.repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-ALW480DA-%3d%3di549695&PartID=549695
Aug 07, 2009 | Amana ALW480DA Top Load Washer
Loud spin noise from Maytag washer
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.
Jan 05, 2009 | Washing Machines
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
