Good evening, I am having trouble with my TV, it will only run for a few moments and then shuts off, I have taken it apart and cleaned the fans, all of them are working, what else can I do
    Top Expert:
  • Computers & ... Master
  • 25,277 Answers
Depending on the make and model it probably requires a power supply repair. Replace all bulging capacitors with identical types and values.
Posted on Dec 27, 2016
2 Suggested Answers
  • 53 Answers
SOURCE: POWER ON FEW SECOND THAN SHUT OFF
hi I'm mhel, your 1st problem was your laptop is overheating, you may try to install a back case blower, which you can find anywhere. and 2nd your laptop doesn't show anything right? I guess you install your RAM in a bad way, try to eject your RAM and put it back again it should the trick. and next time when you tear apart your laptop get some anti-static case to protect your harware. good luck with that..e-mail me if this works...
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
Posted on May 31, 2009
Can I take my fan apart to clean it?
YES ! I have several fans and I have taken them all apart. They are easy and fast to take care of. Only a few screws and some light cleaning and simple oiling and she will run like new. I do mine atleast once a year... post how you do... Tim
Sep 14, 2012 | Lasko Dryers
FAN SPEEDS UP PC SHUTS DOWN
The laptop must be taken apart and cleaned, remove fan and heatsink get a can of compressed air attach straw, now give a good few blasts to the heatsink fins to remove the dirt including fan, Next get rubbing alcohol and clean the old thermal paste from the processor and heatsink, when finished apply fresh thermal compound to both items and assemble.
Jul 03, 2012 | HP Pavilion dv6000z Notebook
My TV turns it self off after a few hour s of viewing
Hi.
The most common problem that causes shut down after few hours is overheating. Overheating however does not necessarily occurr because a faun is broken or because a thermistor is defective. A devective IC may fail and overheat on its own. The fault won't be even called overheating in some case.
The TV must be taken apart and tested by a technician.
Common faults to be tested are:
Fans and tehrmistors.
Convergence ICs.
Ballast.
PSU.
There are also a couple of test point on main controller board to be tested.
Regards.
Ginko.
Nov 09, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Over heating
This laptop is probably due for a deep cleaning. There is probably a dust build-up on the fan intake assembly that is not letting enough cool air into the laptop. You can try spraying it with compressed air, but it should be taken apart and cleaned.
Apr 08, 2010 | Compaq Presario CQ50-215NR Notebook
I have a Viore RPT50V24DX/SMS TV, That just turns off after a few minutes. When it's on it's nearly perfect, but then it quits. The cooling fan is running, and there's not much dust inside. Any Ideas?
A: Check clearances for proper ventilation, as overheating can occur even with the fans running. B: If A checks out then replace the lamp as it is in failure mode. They do not usually just all of a sudden fail. They give symptoms such as this.
Mar 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Ps3 is freezing after 10-15 min have taken mach. apart and cleaned, seems as if fan is running
Try new heatsink paste on the CPU and GPU. Sounds like you are having a heat problem. Check how hot the power supply box is getting as i have replaced a few that got extremely hot and would make the PS3 shutdown, no video, frozen screen ect. If it is the power supply there are a few places you can purchase them online. Good Luck.
Dec 02, 2009 | Video Game Consoles & Games
Tv shuts off after a few minutes akai pt50dl24
Not sure if this will help I have a infocus 61in dlp I've had a lot of trouble with the fan even if the fan is working the control wire or a should say on my TV when it got hot and the wiring broke down so it would shut off I replaced the wires I'm not sure if he'll have that same option but it is something to look at it seems like the projectors or projection TVs have a fit over heat I wish you the best of luck I must clarify the fan goes to my bulb is a three wire the center wire tells the computer to turn everything on my and outside one's is the fan the fan is one directional and this may be of no help as well but a 9 V battery placed across the outside terminals told me the wires were bad I hope some of this information will help if not I hope you get the help you need for it once again good luck
Aug 01, 2009 | Akai Televison & Video
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Over heating
fan filter is probably plugged with dust, fan blades are also probably covered, unit will have to be taken apart and cleaned, lamp is overheating, probably a good idea to replace that lamp or at least order a new one and keep it for when it does finally die out, good luck with it, hope this helps
Nov 29, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
