Question about Panasonic Televison & Video
Panasonic tv reciving no power - Panasonic Televison & Video
How to connect my hdtv to surround for audio
It looks like from my searching you have an optical link on your tv and your reciver. You should just have to choose that as your output on the tv and your input on the reciver. It should be labled something like spdif. In my opinion it is the best cable ever until hdmi came out now its still really good.
Jan 05, 2017 | Panasonic Audio Players & Recorders
Need a repair shop for technics radio reciver.
Find a repair shop that handles Panasonic products. Technics is a related brand.
Sep 04, 2012 | Technics Audio Players & Recorders
Panasonic SA CH46 double cassette reciver not workimg
I HAVE A PROBLEM IN Panasonic SA CH46 double cassette
POWER SUPPLY IS NOT WROKING PLZ TELL HOW >?
Dec 24, 2009 | Audio Players & Recorders
The dishnetwork. Sighn just dances around the screen I push select and nothing happens
This sounds like this may be an issue with your tv 2, make sure your remote is in sat mode by pressingthe sat button. then select, if still nothing take your remote to the recvr and look on the back of the recvr to make sure the uhf ant. is standing straight up if not, straighten and try remote functions. if you stillg et no responce there could be other issues that are simple to fix depending on what kind of equipment you have. you can call 800-333-3474 for assistance or reply with recvr name or model #.
Nov 16, 2009 | DISH Network IR Remote Control
Can not get audio from tv to receiver
You may need to assign the optical audio input to the selected source. Also check to see if the input mode for the selected source on the receiver is set to Auto or Digital.
Sep 29, 2009 | Denon AVR588 Receiver
No power. Dead/ it kinda got shocked.
There is a small fuse on the circuit board - a 20cm F5A - that has probably blown. Unfortunately, though, the PCB (506E) may also have blown and may need replacing.
Mar 11, 2009 | Panasonic DMRES15 DVD Recorder
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Reciving afax
My fax is on tel.mode. how do i change to auto recieve fax.
Thanks
brendanbuck
Jan 10, 2008 | Panasonic Panafax UF-333 Plain Paper...
Televison & Video Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
