I have microwmark cam need din plug to go in tv
I am hooked up via VGA and have the lime green cable hooked up to my tv and the back of my computer but still no sound.
It sounds like you plugged into the TV headphone jack. Unplug it on the TV end so you do not damage anything.
You need to get a mini-DIN to RCA stereo connector. It will have a connector that fits your PC on one end in the lime green audio jack(mini-DIN), and the other end will have two RCA connectors- one white (left) and one red (right) that plug into AUDIO IN on your set. Make sure you follow your TV manual or menu as to making sure the right audio input is used with VGA, and it should work correctly.
Feb 18, 2011 | HP Computers & Internet
How do i install a sega genesis 16 bit to my tv and what kind of cords do i need
Sega genesis has a proprietary plug which goes to a standard RCA Style cable. They go for about $9 on eBay.
Or you can get one from Amazon here.
Apr 29, 2010 | Video Game Consoles & Games
Why don't i have a connection when i connect my laptop to the TV?
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Mar 01, 2010 | Toshiba Satellite Pro L300 Notebook
Can't use the tv as a computer moniter.
Feb 28, 2010 | Venturer PLV36220S1 22 in. LCD TV
Cant hook up laptop to tv
Feb 28, 2010 | RCA L40HD36 40 in. LCD HDTV
How do i wire my tv to dvd
Feb 14, 2010 | Sony DVP-NS575P DVD Player
I don't have signal fom my computer to the vga cable to the tv
Feb 14, 2010 | Televison & Video
I cant make my e1505 view on my tv do i need to change a setting to tell it where to show?
Feb 07, 2010 | Dell Inspiron E1505 Notebook
How can i watch downloaded films on my computer on my big screen tv
u can connect your computer to ur TV thru an adaptor(search in google) that can connect to ur PC's display port (the port on ur PC were u conenct ur monitor) the adaptor will have on one side the similar plug as in your monitor cable and in the other end it will have RAS cable plug
or u can use a DIN plug...but ur computer must have a DIN output...
or u can use something like an external TV tuner card box or ADS instant DVD box....
or u can use a convertor box or cable...it will have a 5 pin DIN connector on one end and RAS plug at the other.
Sound is connected from your sound output(the point which has ur speakers connected) plug/output on PC to the sound in of ur TV...again u can use different combination of pin types...RSA or an ordinary sound connector cable
i found this on Ebay...check this out...
http://cgi.ebay.com.sg/PC-Laptop-to-TV-Connector-Watch-Movies-on-Big-Screen_W0QQitemZ150399235227QQcmdZViewItemQQptZLH_DefaultDomain_216?hash=item23047e349b
Dec 31, 2009 | HP Pavilion dv4000 Notebook
Din cables
You need to know how many pins you need (count the holes in whatever you are plugging the cables into). After that, just buy a cable in any tech store, or on Amazon (Amazon's cables are here: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Daps&field-keywords=din+cable&x=0&y=0).
Sep 19, 2009 | Durabrand Two Screen Car DVD Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
