Question about The Optics
Looking for marlin 39 part that is a tube that holds the shells in??
Will a Marlin model 60 magazine tube fit a Marlin Glenfield Model 99G? I'm looking for a tube for my sons 99 Thanks
I'm guessing 'inner' tube. Maybe this link will help. Doesn't show the 99G but has the lengths listed as 20 13/16" and one at 17 something.
$30. Talk with them and see what they say if you don't feel confident in just picking one out and buying it.
Search Numrich Gun Parts
Oct 12, 2017 | Optics
Will the 407746 marlin mag. Fit in a marlin 795
So, you love the look of sustainable, eco-pleasant bamboo flooring, and the idea of reduced-flow bathrooms and geothermal heating get the eco-friendly warrior in you all excited. There's only one problem. AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Jan 10, 2017 | The Optics
Where could I get the inside tube for a marlin 783 22 mag
look online for part company that carry what you need http://www.gun-parts.com/marlin/ is just one of many
Aug 14, 2016 | Optics
Year for Marlin 1894: 94010182
Here you go. It is a question often asked.
  • Model 1894 - Marlin Firearms www.marlinfirearms.com/Firearms/1894Centerfire/1894.asp Model 1894. Built in the tradition of one of Marlin´s oldest lever-action designs, the Model 1894 is an elegant carbine chambered for handgun calibers.
  • Marlin Serial numbers - OldGuns.net oldguns.net/sn_php/marlinlookup.php Marlin Lever Action Rifle Serial Numbers 1883 to 1906 (Including Models 1881, 1888, 1889, 1891, 1892, 1893, 1894, 1895 and 1897.)
  • Marlin 1894 serial number question - Marlin Firearms ... www.marlin-collectors.com > ... > Cowboy Guns Savvy Jack; When Marlin developed this serial number system, they used the current year, subtracted from 100 to determine year of manufacture.
  • Marlin Serial Numbers = Dates of Manufacture ' Gun Values ... www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture... Marlin Serial Numbers = Dates Of Manufacture ... Marlin rifle with serial number on bottom stock tang, ... I have a model 1894 Marlin 32-20 sn 149833.
  • Marlin Model 1894 38-40 Serial Number Question - M14 Forum m14forum.com > M14 Forum > Gun Forum > Lever Action
    • 16 POSTS
    • FIRST POST: 2013-09-12
    2013-12-09 · Marlin Model 1894 38-40 Serial Number Question. This is a discussion on Marlin Model 1894 38-40 Serial Number Question within the Lever Action ...
  • IMPORTANT Model 1894 - Marlin Firearms www.marlinfirearms.com/pdfs/manuals/MFC_Centerfire_1894.pdf · PDF file CENTERFIRE Lever Action Rifles Model 1894 IMPORTANT This manual contains operating, care and maintenance instructions. To assure safe operation, any user of ...
  • Marlin Model 1894 Lever Action Chambered In .32-20 https://www.bigironfirearms.com/marlin-model-1894-lever-action-in... Marlin Model 1894 chambered in 32-20, serial number 162 manufactured 1898, 24" Octagon Barrel with full length tube magazine & Lyman Tang Sight.
  • Jul 05, 2016 | Optics
    How do I tear down marlin 39a 22 rifle
    go to you tube and type marlin model 39 22cal terdown. I have done this a lot of times chances are someone will show you what to do,
    Feb 12, 2015 | Optics
    Marlin rifle model 795 jams intermittently
    It takes about 250 rounds to break in a gun. Try some hotter ammo and see if the problem disappears, if so, call Marlin and ask them for their solution if you want to keep using Federal, you might want to try some Remington standard velocity target, it is very accurate in most guns.
    I would shoot it for at least 500 rounds and clean it from powder debris in chamber and receiver bolt and trigger group and try it again, however don't hesitate to get a hold of Marlin, they are nice folks.
    Feb 12, 2013 | Marlin 795 Semi-Automatic -22LR Rimfire...
    Hello , we just bought a new home defence pump shot gun and we can load 5 shells into the magazine but it will not load a shell into the champer when we operate the pump.
    check the elevator and make sure its working properlly and thsat its no damaged, jammed up, or something blocking it. unload your shotgun fisrt.
    Feb 12, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
    How do i remove the bolt in a marlin 783 .22 magnum?
    Remove the magazine tube and make sure the gun is empty. Open the bolt,take the safety off and squeese the trigger. Continue to hold the trigger back and gently pull the bolt back out of the breech. I beleive that is all there is to it. Good luck with your Marlin.
    Nov 25, 2010 | Crossfire Rock & Ice Climbing
    Optics Logo
    Top The Optics Experts
     steve
    steve
    Clyde Ottaway
    deton8 von Splosion
    Are you a The Optic Expert? Answer questions, earn points and help others
