Question about Health & Beauty
TGA Mystere mobility scooter. Scooter drives perfectly but drains batteries within 5 minutes of driving. Have tested with brand new batteries but still does the same. Help!
  • Health & Beauty Master
  • 1,054 Answers
Hi again ring TGA PARTS FOR A PRICE ON CONTROL BOX 0117 329 1740 good luck i think u need to check THE BATTERIES condition buy a BATTERY LOAD TESTER .OF E/BAY COST APROX ,$35 ,.THIS WILL GIVE U A TRUE READING ON THERE CONDITION,,. Cheers
Posted on Dec 28, 2016
  • Heidi Millington Dec 28, 2016
    Already done a load test and they are fine. As is the solenoid brake and motor. I'm wondering if the digital touchscreen may be faulty ?
  • Jeff Tilburn
    Jeff Tilburn Dec 29, 2016
    Hi about the motor if there is a small fault with field coil or stator (armature) it will drain a lot of power have u had the motor tested on a growler for faults.... Cheers jeff
4 Suggested Answers
SOURCE: we have lost the instruction manual for a TGA
If you contact TGA 01787 882244 they would be able to provide you with a manual, it is chargable though.
Posted on Jul 19, 2010
  • 17970 Answers
SOURCE: my TGA eclipse mobility scooter
Sound like a electrical problem
Keep in mind the new device and its possible that you have warranty for this, you can reach they using the contact details below:
Scooters Mobility Ltd
Suite 3
40 Melton Road
Oakham, Rutland
LE15 6AY
T: 0845 273 9717 (local rate)
F: 01572 801 075
Try this before to do something, you could lost the warranty..
Keep us updated.
Posted on Mar 31, 2011
  • 49159 Answers
SOURCE: TGA Mystere scooter very hesitant in forward gear but ok in reverse. Brake is fine , batteries fine. Would this be throttle pot fault?
that would be my first guess . sometimes spraying contact cleaner on it may help
Posted on Mar 30, 2016
What is the reputation of the tga mystere?
hi , they are solvable, if you get bad connectors or the scooter has got wet then you need help cleaning the connectors...refitting making sure every connector is a tight fitting...
May 03, 2014 | Health & Beauty
Electrics wont work
Please be more specific. Any flash or beep codes? Make\Model\Year of scooter? Is wig-wag pot {potentiometer} within tolerance? [5,000 ohms +/- 5%]
Mar 13, 2014 | Health & Beauty
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Tga mystere
hi, so no lights on the control panel,,,, have you checked the fuses , if i remember correctly there is one located on each set of battery leads.. Take care when checking this...
Feb 06, 2014 | Health & Beauty
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
TGA mystere mobility scooter error code 02 battery fault showing without key in ignition
Hi Dont know about Error 02, byt if scooter is less than 1 year old get the people you got it from to fix it under warranty,
Jan 28, 2013 | Health & Beauty
Hello My wife has a go go ultra scooter and all the sudden it seems like the brake is on all the time while driving forward and killing the battery.The batteries check at 12.7 full charge but die within...
well there is another way of checking the battery's and thats by load testing them.
1)Fully charge the battery's
2) load test both batterys make sure they are reading close to the same
If both battery's check out good than ,The next step would be to check that brake assembly.
1) Put the scooter on blocks so when you drive it doest runaway
2)Take the rear wheel off that the brake side is on
3) Put the scooter in drive with some tape or rubber band to hold it in drive
4) Make sure theres nothing in the way if the scooter should fall
5)check your break if it abnormally hot
If it is in fact abnormally hot ,the you have a break problem.
Hope i was able to help,good luck..
Jan 17, 2011 | Pride Mobility Products Go Go Ultra X 3...
I will drive for about a mile with full power with little power lose.then all of a sudden,ill have extreme power loss . within 1quarter mile ill lose all power.something drains the batteries
Batteries do not provide a linear output during usage, but having it die out within a mile or so tells me that one of the battery cells is becoming weaker than the rest. If you're a handyman, you can save yourself a ton of money by replacing only the batteries (try interstate batteries) instead of going to the scooter store and purchasing the batteries and case.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
81 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
