Question about Plumbing
How i install the water seal in a pedrollo pump
A surface water pump
My water pump stopped working
More details are required to analyze the problem. Is there water available to the pump, does it run but no water etc. etc.
Jun 21, 2016 | Pedrollo PJ3015-CF N/A 1-1/2 HP High...
How do I replace the timing belt and water pump on my 1991 sun bird. 2.0 liter engine
Water Pump: Remove timing belt rear protective covers, Remove lower radiator hose from water pump. Remove water pump attaching bolts then the water pump and sealing ring, Clean engine block and water pump sealing surfaces, then apply a 3/32 inch of RTV sealant to sealing surfaces. While RTV sealant is still wet, install water pump. Tighten attaching bolts finger tight. Install lower radiator hose on water pump, then belt rear protective covers. Install timing belt
Jan 18, 2013 | Cars & Trucks
Replacing a water pump
The instructions below should apply for your car. There are different engines for that model but the instructions are basically the same.
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the serpentine belt. Removal of the alternator and/or bracket may help give more room for easier access.
  4. Remove water pump attaching bolts and nut, then remove pump.
To install:
  1. Clean the sealing surfaces, then place a 3/32 in. (2mm) bead of RTV sealant or equivalent on the water pump sealing surface.
  2. Coat the bolt threads with a pipe sealant GM part no. 1052080 or equivalent.
  3. Install the water pump, then tighten the bolts to 10-24 ft. lbs. (14-33 Nm).
  4. Connect the negative battery cable.
  5. Fill the cooling system, then check for leaks. Start the engine and allow to come to normal operating temperature. Recheck for leaks, then top off the coolant.
Dec 26, 2011 | 1990 Oldsmobile Cutlass Ciera
Need instruction for replacing water pump 2004 GMC Envoy 4.2 liter engine.
TO REPLACE WATER PUMP.FIRST YOU HAVE TO DRAIN THE COOLANT SYSTEM. REMOVE AIR INTAKE DUCT AND RESONATOR. REMOVE THE RADIATOR SHROUD AND FAN CLUTCH ASSEMBLY REMOVE THE DRIVE BELT. REMOVE WATER PUMP PULLEY.YOU NEED A PIN SPANNER WRENCH OR STRAP WRENCH TO HOLD WATER PUMP PULLEY WHILE LOOSEN WATER PUMP PULLEY BOLTS .YOU CAN BUY STRAP WRENCH OR RENT PIN SPANNER WRENCH AT AUTO ZONE PARTS STORES OR OTHER STORES HAS TOOLS CAN BE RENT. ONCE WATER PUMP PULLEY REMOVED. REMOVE THE WATER PUMP MOUNTING BOLTS. REMOVE WATER PUMP. IF WATER PUMP STUCK YOU CAN TAP WITH SOFT FACE HAMMER OR A LONG PIECE OF ROUND WOOD.WHEN WATER REMOVED.YOU NEED TO CLEAN THE SEALING SURFACE CAREFUL DONT SCRATCH SEALING SURFACE. YOU CAN BUY CAN OF SPRAY GASKET REMOVER.CLEAN SURFACE GOOD THEN WIPE WITH LACQUER THINNER OR ACETONE.THEN GET WATER PUMP NEW GASKET MATCH HOLES UP WITH GASKET TO WATER PUMP. ONCE HOLES MATCH UP APPLY RTV SEALANT ON BOTH SIDES WATER PUMP GASKET. THEN PUT GASKET ON WATER PUMP THEN INSTALL WATER PUMP TO VECHICLE.TORQUE WATER PUMP BOLTS TO 89 INCH LBS .TIGHTEN WATER PUMP PULLEY BOLTS TO 18 FT LBS THEN PUT EVERY THING BACK VISA VERSA.
Aug 26, 2011 | GMC Envoy XL Cars & Trucks
Water pump location
Here are the procedures.
WATER PUMP
Removal
1. Drain cooling system. Remove timing belt. Remove right ignition coil. Disconnect coolant hose from coolant inlet housing.
2. Remove retaining bolts and separate coolant inlet housing and "O" ring from water pump. Remove retaining bolts/nuts and water pump. Remove "O" ring from coolant by-pass pipe which fits into rear of water pump.
Installation
Ensure sealing surfaces are clean. Install NEW "O" ring on coolant by-pass pipe. Lubricate "O" ring with soapy water solution.
2. Apply a .08-.12" (2.0-3.0 mm) diameter bead of sealant on mounting surface at rear of water pump. Install water pump. Ensuring water pump engages over coolant by-pass pipe. Tighten
fasteners to specification.
See
3. To install remaining components, reverse removal procedure. Fill and bleed cooling system.
Jan 05, 2011 | 1992 Lexus Ls 400
I need to replace the water pump on a 1990 2.5 dodge caravan.
WATER PUMP - 3.3/3.8L ENGINE
REMOVAL
Drain Cooling System. Refer to procedure in this section.
Remove accessory drive belt. Refer to procedure in this section.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws Water Pump - 3.3/3.8L Engine Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface.
INSTALLATION
Install new O-ring into groove Water Pump Body
Install water pump to chain case cover. Tighten screws to 12 N·m (105 in. lbs.)
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 N·m (250 in. lbs.)
Install accessory drive belt. Refer to procedure in this section.
Install right front lower fender shield.
Refill Cooling System. Refer to procedure in this section.
Aug 14, 2010 | 1990 Dodge Caravan
Want to know how to change a thermostat on my 2004
It Depends on which engine you have, this is how it goes for both. I use a little RTV with a new ring as well.
THERMOSTAT REPLACEMENT (4.2L ENGINE)
Removal Procedure
1. Remove the necessary coolant from the radiator.
2. Remove the generator.
3. Loosen the outlet hose clamp at the thermostat housing. Remove the outlet hose from the thermostat housing.
4. Remove the thermostat housing bolts.
5. Remove the thermostat housing from the engine block.
6. Clean all of the surfaces of the thermostat housing.
7. Clean the sealing surface of the engine block.
Installation Procedure
1. Install the thermostat housing to the engine block.
2. Install the thermostat housing bolts.
Tighten: Tighten the bolts to 10 N.m (89 lb in).
3. Lubricate the inner diameter of the radiator hose with engine coolant.
4. Install the outlet hose to the thermostat housing. Secure the hose with the clamp.
5. Install the generator.
6. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
7. Inspect all sealing surfaces for leaks after starting the engine.
THERMOSTAT REPLACEMENT (5.3L ENGINE)
1. Drain Radiator and remove the radiator outlet hose.
2. Remove the water pump inlet bolts.
3. Remove the water pump inlet and thermostat from the water pump.
IMPORTANT: The thermostat is not serviceable separately. The water pump inlet and thermostat must be replaced as an assembly.
1. Install the thermostat and thermostat housing to the water pump.
2. Install the thermostat housing bolts.15 N.m
3. Install the radiator outlet hose.
4. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
5. Inspect all sealing surfaces for leaks after starting the engine.
Mar 17, 2010 | 2004 GMC Envoy
Water pump in a kia saphea how do u change it 2001
Below are the steps..
Disconnect negative battery cable.
Drain engine coolant.
Remove timing belt (please make sure you know how to do this, otherwise, seek help from a certified mechanic) Remove tensioner and idler. f644145.jpg Remove water pump. dbfdc5c.jpg Remove any gasket fragments, dirt or oil from sealing surfaces. Install new gasket on water pump. To prevent dropping the gasket when installing, put sealant in gasket groove. But do not apply to sealing surfaces. Install water pump. Install tensioner, idler and timing belt. Fill engine coolant. Connect negative battery cable. Start engine and check for leaks. Regards, Jeep Brainy
Sep 09, 2009 | 2000 Kia Sephia
INSTALLING A NEW WATER PUMP
REMOVAL
  1. Drain Cooling System.
  2. Remove accessory drive belt.
  3. Remove right front lower fender shield.
  4. Remove water pump pulley bolts and remove pulley.
    1. Remove water pump mounting screws. Remove water pump.
    2. Remove and discard O-ring seal.
    3. Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface.
    INSTALLATION
    1. Install new O-ring into groove.
    2. Install water pump to chain case cover. Tighten screws to 12 Nm (105 inch lbs.) .
    3. Rotate pump by hand to check for freedom of movement.
    4. Position pulley on pump. Install screws and tighten to 30 Nm (250 inch lbs.) .
    5. Install accessory drive belt.
    6. Install right front lower fender shield.
    7. Refill Cooling System.
Jul 03, 2009 | 2000 Dodge Caravan
Plumbing Logo
82 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
