Question about Camping, Backpacking & Hiking
What goes where???? Stinger s32p assembly guide?
Where do i send my light to be repaired
Not to many places are around anymore that I know of that fix appliances whether it's a flashlight or whatever, unless you know somebody personally that fixes items on the side as a hobby. Maybe sometimes the company of the product offers a repair or replacement. But sometimes the cost of that process out ways the cost of a new one. That's partially the reason most places don't repair.
Feb 17, 2014 | Streamlight Stinger Led Flashlights Led...
The red light in the stinger charger is blinking on and off rapidly. Is that normal?
not with my stinger flashlight
send it back, lifetime warranty... you have to build an account online and then print a shipping label... WONDERFUL company to deal with
Dec 29, 2013 | Stinger Camping, Backpacking & Hiking
Johnson Outboard Motor Manual
its in the remote control box as you should have a kill lanyard button on the side so if you fall out it stops the engine ! split the box and easy replacement or check , make or brake reading on amulti meter set on ohms !
Jun 09, 2013 | Boating
I am getting engine noise? i have a mono block amp for my bass and another amp for my mids. How do I hook up the stinger SGN20 ground loop isolator?
It goes between the source and the amplifier , I don't know if it will work with guitar pickups, but no harm in trying. Also designed for stereo, but you could try dual mono I suppose. Not sure if that will work either but here are the instructions. You will need 2 mono female Jack to male RCA and 2 mono female RCA to male Jack adapters, (unless your guitar output is stereo in which case you will need 1 stereo Jack to 2 RCA etc. Good luck, it might work but I don't think it was designed for the use you have in mind. Will you let us know how you get on?
Mar 07, 2011 | Stinger Sgn20 Ground Loop Isolator
My computer does not start in normal mode .... i suspect there is a virus infected application which does not uninstall ..
ok boot windows in safe mode
click start>run> and type there "msconfig"
aaarwind_12.jpg 1st select the tab "Startup"
2nd click "diable all"
3rd click "apply"
4th click "OK"
after that windows will ask for restart. do restart the windows. if you have virus problem this method will fix most of the cases. if same problem persists you check RAM or DISPLAY hardware and drivers. best of luck.
Jan 20, 2011 | Computers & Internet
My streamlight stinger xt flashlight won't charge in the holder, however, the second battery does charge in the "piggyback"
Could be a lamp holder or charger problem. I suggest going to Streamlight's website and find an authorized service center in your area or send it to the factory for repair.
Mar 28, 2010 | Stinger Streamlight XT Rechargeable...
Where is the on/off switch is there one? doesn't seem to be lighting up
It is the rubber button right near the lamp assembly. Some Streams have a button on the tail cap.
Oct 20, 2009 | Stinger Streamlight 75000
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
Streamlight stinger not bright
No! the last thing you want to do is get another light, if this light is still in top shape I suggest you send it back to Streamlight for warranty repair. Lifetime warranty on the light alone as far as the battery goes if you're getting an authentic Streamlight Rechargeable battery there shouldn't be a problem. If it's a knock-off battery you're on your own. Check this website out send it back to the address in contact or find an Authorized service center in your area. From what you're telling me here I honestly think it's a bad battery, I could be wrong it may be a bad switch. The switch is covered under a lifetime warranty. So take advatange of it while you can! ;) hope that helps.
Jan 24, 2009 | Stinger Streamlight 75000
Clothes Dryer belt assembly
yes,make sure you have the ribbed side on the drum-mike
Nov 04, 2008 | GE DCVH515EF Electric Dryer
Camping, Backpacking & Hiking Logo
845 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
