How solve 2420 dc controller error - Office Equipment & Supplies
My ir 2420 copy error 00805 - 0000 please tell me solution
First Clear The Error.
Asterisk * # Asterisk * then Service mode
IF problem persists Follow Below
The Fan is faulty Replace with a new one.
If problem persists Replace DC Controller
Jun 29, 2016 | Office Equipment & Supplies
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
How to solve Error code e000007-000 canon 2420
Sep 03, 2015 | Canon Office Equipment & Supplies
Canon copier error e000007-0000 canon 2420 image burner
Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Mar 10, 2015 | Canon Office Equipment & Supplies
I have a copy machine canon 2420 I have error code E000007-0000
Check the connector of the fixing film sensor,replace it if necessary,or replace fixing film or DC controller
Feb 08, 2015 | Canon Office Equipment & Supplies
Code Error on Ir 2420 l display **E000003-0000 what can i do please solve this...
dear
pl. do check the fixing film assy. heater strip contact points. if corrosion clean/replace it.
Check the DC card.
Also check the supply voltage at the machine input.
Thanks.
Dec 04, 2014 | Canon Office Equipment & Supplies
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
My printer is giving an error message..."error 57.03"to continue turn on then off....i do it to no avail.help me
This is a Fan issue you have 2 of them one on the front right side and one on the left. if you remove both covers see which one is not working
Now if their are both working then you will need to replace the ECU (Engine Control Unit).
I've attached a link that shows you how to remove the covers off the 2420 it's a pdf file .
And the Left side cover will need to be removed to access the other fan.
Oct 18, 2010 | HP LaserJet 2420 Printer
My hp 2420 pcl 5e STOP PRINTING SUDDENLY. & showing me (FUSER ERROR) TELL ME WHAT CAN I DO TO SOLVE THIS PROBLEM I TURN IT OFF AND BACK ON 3 TIMES BUT PROBLEM IS STILL THE SAME.
Hi
Problem either fuser faulty or dc controller card faulty first check for faulty fuser & after then dc controller fuse of fuser.
Thanks
Sep 25, 2010 | HP LaserJet 2420 Printer
19 people viewed this question
jasbo
jasbo
