Question about Belling Ovens
Belling G755 - the oven button won't stay in. If I hold it in the oven stays lit but it won't stay in on it's own.
Will a new knob fix it or is it something else?
docjohn174
  • 943 Answers
SOURCE: Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 12, 2009
SOURCE: Belling countrychef - Main oven gas doesnt stay on
the flame failure device has failed ,you will need a new thermocouple
Posted on Nov 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: pilot light is lit both on oven and stove top...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Posted on Apr 06, 2010
Testimonial: "Thanks ! I will use this to investigate further... u da man !"
SOURCE: Beko SCG 7521 gas cooker flame won't stay lit in oven
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Posted on May 15, 2010
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
My gas oven won't stay lit when knob is released
The thermocouple is faulty. This needs to be replaced by a registered gas safe engineer
Feb 22, 2011 | Belling Ovens
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Ovens Logo
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
