Question about Invacare Health & Beauty
Invacare TDX SP - Lock light flashing so will not move. 6 flashes pause 6 flashes etc. Can't find it in manual. Help please.
  • 3 Answers
SOURCE: 10 flashing lights then 9
you need to see if you can get tv on in service mode.
if it will only work in service mode then yes replace those 2 diodes
Posted on Aug 25, 2008
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony trinitron WEGA won't turn on and standby
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Visit the link below so you can talk to Sony either on the phone or via online chat for your full range of options.
http://esupport.sony.com/US/perl/support-contacts.pl?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
  • 708 Answers
SOURCE: 2003 ford ranger airbag light is flashing code
46--- Driver Pretensioner Circuit Resistance High
That means the buckle in you driver side seat belt system has failed. It has an explosive device called a pretensioner in it which is designed to pull you into place microseconds before the airbag deploys. That component has failed and has deactivated the airbag system. You will need to replace the 'buckle pretensioner'.
But before you do, please get real familiar with the system you are working on before you cause additional damage, hurt yourself or deploy the bags accidentally.
http://www.airbagsolutions.com
http://www.airbagsolutions.com/vehicles_list.aspx
http://www.airbagsolutions.com/demo.aspx
Posted on Nov 17, 2009
  • 217 Answers
SOURCE: Check engin light
it is flashing the codes if you got the sequence right it is codes 12,21,55 what engine? 12 battery disconnect,21 isO2S shorted to voltage, and 55 is MIL may not come on
Posted on Mar 06, 2010
Testimonial: "Thank you very much. I have got the same diagnosis from other source. Claude"
Invacare Colibri. Why doesn't it work?
hi lesley, Is the tiller status light flashing ? if so how many flashes before a pause etc other wise tell me what 's happening so i can help you ...
Regards
Help me,,,, Help you ..
Sep 27, 2015 | Health & Beauty
Unlock handset
See if there is a yellow light blinking on the joystick as well. Count how many times the yellow light blinks between pauses and blinks again. When you have the number of time the yellow light blinks (between 1 and 9 times) look it up in the owners manual or repost it here to be answered.
Oct 15, 2014 | Invacare Health & Beauty
I have the tdx sp and the wrench light is flashing 7 times what does this mean?
There is a problem with the remote joystick. Could be a bad connection or bad harness to the remote joystick. If harness is fine then the joystick has issues and needs to be replaced or rebuilt.
Try the 4-wire harness first.
Nov 03, 2013 | Invacare Supply Group Invacare Pronto M91...
Troubleshooting an invacare tdx sp electric wheelchair
Behind the drive wheels is a selenoid that has a flip up for "PUSH" and flip down for "DRIVE", make sure they are both in "DRIVE". That's what worked for me.
Oct 13, 2012 | Invacare Health & Beauty
A wrench light is on the indicator and the chair will not drive. Help! Thanks, Michael
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
May 31, 2011 | Electric Mobility Invacare Pronto M41...
The joystick on my TDX wont make the chair move and a key insignia flashes. Battery is fully charged and the other controls ( chair tilt and footplate lifts all work OK. What can the possible problems be...
count the number of flashes of the wrench and it will tell you what the error is. ie 4 falshes right motor Your owners manual should have the flash codes in it and will explain the error you are having Hope this helps
Feb 27, 2011 | Invacare Health & Beauty
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
We are trying to move the chair and the service light keeps coming on
The service light indicates a problem. Count the number of flashes. ie flashes 4 times pauses flashes 4 times etc. If you have the owners manual the flash code section will tell you what the number of flashes mean: 3 flashes left motor 4 flashes right motor. You will have to contact a service company to repair the chair once you find out what flash code you have. If Medicare pirchaed the chair then they will pay for most of the repair cost. Hope this helps
Aug 25, 2010 | Electric Mobility Invacare Pronto M41...
Stability locking kit
The M51 does not have a stability locking kit. The Invacare TDX SP has a gas strut stability locking kit that just had an extensive recall campaign associated with it. Please describe your issue in greater detail.
Jul 16, 2010 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
95 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
