Question about GE Refrigerators
The fridge lights are on but all the computer settings are not showing and fridge is not cooling
  • GE Master
  • 4,654 Answers
I need your model number but when that happens its a control board or the digital logic board is defective. Let me know, Thanks, Sea Breeze
Posted on Jul 21, 2009
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Whirlpool side by side GD25HAXNQ00 Light is out in fridge - including lights showing temp setting - it is not the bulb - what else can it be. Cooling is still fine with both fridge and freezer
you may need a board that is located on the rear of the fridge. pull the fridge out and unplug from outlet. locate the cover on rear and remove screws and open plastic cover. replace the board and new bulb. try this site and it is a bit pricey. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-electronic-control-board--item-number-ap4334000.aspx but to call a repair service it will be around 300.00
May 03, 2012 | Whirlpool Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
The fridge is too warm (15) but the temp. is set at 4. The temp. indicator sometimes shows 2 but the temp. inside the fridge is still 15
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Both sides stoped cooling and freezing
Well, it needs gas for it to work. try to buy some.
Nov 01, 2009 | Samsung RS265LABP Side by Side...
GE Side By Side Stopped Working
Either a bad interface\display board or a bad main computer. I would try the main computer first.
Jun 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
