I have Defy laundromat 1100. .the machine can no longer drain water after a wash
    Top Expert:
  • Washing Mach... Master
  • 49,126 Answers
Either the pump is bad or the PCB has failed .call a repair service
Posted on Dec 27, 2016
E2 is flashing on the screen of my defy Fuzzy washing machine in the rinse program
I'm seeing that water is pumping very slow,like you have a twist or clog in the drain line or the drain line isn't positioned correctly.
I'm using this manual,as there wasn't a model number indicated:
Jan 10, 2018 | Washing Machines
What's your question?defy toploader drain motor keeps running as soon as power switched on!!
Hi some machines do this to empty any water that may have been sitting in the bottom of your washing machine and the water has went stagnant. It should stop when you start a new washing cycle if it does not you will have to have your machine looked as it would just be draining the water as it goes in.
Mar 18, 2016 | Washing Machines
My Defy DAW 365 washing machine goes through the whole washing cycle but it just won't spin. It does drain between the washing cycles.
If the poly-vee drive belt in your washing machine has snapped, the motor will no longer be able to turn the drum. The drive belt is an important component of any washing machine as it drives the motion of the unit where the clothes are washed and spun. If your washing machine is making a loud noise or no longer spins, then the belt is probably worn or damaged.
Oct 23, 2015 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
I have a Defy Laundromaid Electro Logic 1100 washing machine and it is now giving me an E9 error. What could be the problem?
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
May 28, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
