We have no internet connection on our TVs, so can't get catchup tv, how can we sort this?
Why am I unable to get catchup programs?
Try a hard reset to this set; and check it after. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 25, 2016 | Samsung Televison & Video
Is the tv internet ready?
Smart TV: Internet-ready LED TVs - Best Buy
Best BuyShop Best Buy for Smart TVs. Connect a smart TV to the Internet for access to movies, music, social networking and more.‎Samsung 32" Class 31.5" - ‎Insignia - ‎Sharp - 43 Class (42.6 Diag.)
Smart TV vs. Internet Connectable - What's the Difference ...
Best BuyIn the home theater world, there are now many options for getting Internet content onto your HDTV. This is an exciting development, but it means the world of TV ...
Dec 29, 2015 | Televison & Video
I cant get my new sony Bravia to play any catchup programmes. I can access the catchup/iplayer sites but they wont play selected programmes.
This may not be as helpful as either of us would wish, but I had the same problem with my Finlux TV. It seems to be a fact that they do not make all programmes available on "Catch Up", as I found out one day when trying to watch something on Catch Up online, when some of them were only available for a very short time unless you were subscribing to one of the major entertainment suppliers.
Jan 01, 2015 | Sony Televison & Video
I don't kno how to get my tv to take internet nor do I see the internet option
you can use your HDMI port on your tv hooked to a laptop and use your tv as a monitor, Smart TVs do not have APPS written yet that make them surf the net.
Jun 25, 2014 | Computers & Internet
Need to connect my tv to the internet
Wifi dongle will available for TVs. If you had USB port on TV,connect that dongle on that and access internet.
Nov 10, 2013 | Sharp LC46SB54U 46 in. LCD TV
Can I get help with connecting my smart tv to internet as its not working for me thanks a million :)
Hi, commonly these TVs use a network cable for connecting to Internet through a router, another TVs are wireless enabled, in this case you need a WiFi router to get Internet in your smart TV. The process is similar as you connect a computer to Internet but the keyboard of your TV is the remote control, some smart TVs can work with standard wireless keyboards and mices to surf Internet as with a computer.
Nov 01, 2013 | Televison & Video
What type of cord do i connnect from acer to watch movies on the tv
Laptops usually have a serial connection so you can use that to connect to your TV. Now, depending on your TV input connections you need to buy the right cable. Buy this sort of cable if you have serial input connection
if not, then most of TVs have RCA input connection, so you need this sort of cable
Now based on your sound connections, you will need a cable for that. Either one of this, if you have this type of input
or another converter to RCA for sound.
Jan 16, 2011 | Acer Aspire 55421462 Notebook
I am trying to connect and play my pc on my lcd tv
It depends on what sort of television you have and the connections that it has available.
1. The easiest way is to get a VGA cable like the one in the image below if your TV has a VGA input connection.
img src="" alt="VGA"/>
Notice this is for video, you will need a double audio jack cable to connect sound, if your TV has this sort of input, otherwise you are better of with option two.
2. If your TV doesn't have a VGA connection, you need to get a VGA to RCA adapter like in the image below. Majority of the TVs have a RCA input connection, so if your has one you need to get this adapter and an RCA cable.
img src="" alt="VGA2RCA"/>
Dec 12, 2010 | Toshiba Satellite L455DS5976 Notebook
How to connect it
Well, you don't give much to go on...
Assuming you have a newer system, it should come with a video cable of some sort and a power cable of some sort. On every console I know of, they both have easy-to-find ports on the back to plug in to. The power cable goes into the wall socket and the video cable goes to your tv. Nowadays, video game systems have either AV cables (red, yellow, and white) or component cables (red, blue, and green) that ship with them. Old systems like the NES may come with an old RF connection (the one that is reminiscent of a cable connection--witht the screw thing on the end). Old tvs may not have AV inputs for the RYW or RGB connections. These will require an RF converter.
Any recent tvs have RYW inputs. They are generally on the back, or on flat tvs on the side, and they are usually color coded to match the type of wires that go into them. Mono tvs have only a white (sound) and a yellow (video). Stereo tvs have a red (right sound) in addition to these. High-def tvs have component inputs as well for higher quality. If you have an xbox 360, find the RGB cables and then find the color coded component inputs on your tv. Then also plug in the red and white sound jacks. make sure your xbox cable is switched to the component setting. This is a little switch that is on the connector where the cable meets the xbox.
This is the gemeral way to hook up a video game system, Anything else will require more details.
Jul 29, 2008 | Video Game Consoles & Games
Televison & Video Logo
Top Televison & Video Experts
