We have no clue Nernst connection on TVs, so we cannot get catchup tv.how can we sort this
  • Jeff Tilburn
    Jeff Tilburn Dec 27, 2016
    Hi Theresa bray, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Is insignia ns-rc02a-12 a smart tv. Can I get Netflix on it?
The NS-RC02A-12 is a remote control that shipped with several Insignia TVs. Since one of the TVs that came with this remote is the NS-39L240A13 which does not have wi-fi or an ethernet connection port, I suspect that none of these TVs are Smart TVs. See https://www.insigniaproducts.com/pdp/NS-39L240A13/5061732 for the specifications.
You can make it a Smart TV and get Netflix by adding a Roku, Fire Stick or other streaming TV stick or box to one of the HDMI ports. If you have the ports occupied, you'll need some sort of HDMI switch device to share the input.
I hope this helps.
Feb 07, 2018 | Insignia Televison & Video
Why am I unable to get catchup programs?
Try a hard reset to this set; and check it after. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 25, 2016 | Samsung Televison & Video
I cant get my new sony Bravia to play any catchup programmes. I can access the catchup/iplayer sites but they wont play selected programmes.
Hi
This may not be as helpful as either of us would wish, but I had the same problem with my Finlux TV. It seems to be a fact that they do not make all programmes available on "Catch Up", as I found out one day when trying to watch something on Catch Up online, when some of them were only available for a very short time unless you were subscribing to one of the major entertainment suppliers.
Cheers
Jan 01, 2015 | Sony Televison & Video
How to connect ipad to my tv
You will need Apple Composite AV Cables to connect the iPad to your television. The cables can be purchased online or at your local Apple store.
You can also stream your iPad to your television if you have an Apple TV by using Apple's Airplay.
Hope that helps!
Aug 10, 2012 | Apple iPad 16 GB 3G Tablet PC
What type of cord do i connnect from acer to watch movies on the tv
Laptops usually have a serial connection so you can use that to connect to your TV. Now, depending on your TV input connections you need to buy the right cable. Buy this sort of cable if you have serial input connection
if not, then most of TVs have RCA input connection, so you need this sort of cable
Now based on your sound connections, you will need a cable for that. Either one of this, if you have this type of input
or another converter to RCA for sound.
Jan 16, 2011 | Acer Aspire 55421462 Notebook
I am trying to connect and play my pc on my lcd tv
It depends on what sort of television you have and the connections that it has available.
1. The easiest way is to get a VGA cable like the one in the image below if your TV has a VGA input connection.
img src="http://www.fixya.com/uploads/images/mariolands_13.jpg" alt="VGA"/>
Notice this is for video, you will need a double audio jack cable to connect sound, if your TV has this sort of input, otherwise you are better of with option two.
img src="http://www.fixya.com/uploads/images/mariolands_12.jpg" alt="VGA"/>
2. If your TV doesn't have a VGA connection, you need to get a VGA to RCA adapter like in the image below. Majority of the TVs have a RCA input connection, so if your has one you need to get this adapter and an RCA cable.
img src="http://www.fixya.com/uploads/images/mariolands_14.jpg" alt="VGA2RCA"/>
Dec 12, 2010 | Toshiba Satellite L455DS5976 Notebook
How do we connect our Toshiba Satellite laptop P105-s6104 to a Panasonic tv
It depends on what sort of television you have and the connections that it has available. The easiest way is to get a VGA cable like the one in the image below if your TV has a VGA input connection.
mariolands_13.jpg If your TV doesn't have a VGA connection, you need to get a VGA to RCA adapter like in the image below. Majority of the TVs have a RCA input connection, so if your has one you need to get this adapter and an RCA cable.
Dec 12, 2010 | Toshiba Satellite P105-S6104 Notebook
Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
Jul 04, 2009 | Televison & Video
Picture scrolls up
HAD THE SAME PROBLEM ,, TILL I GOT THE S VIDEO CABLE FOR MY SEGA,,BETTER PICTURE,,NO MORE LINES ,,
Aug 16, 2008 | Sega Genesis Console
How to connect it
Well, you don't give much to go on...
Assuming you have a newer system, it should come with a video cable of some sort and a power cable of some sort. On every console I know of, they both have easy-to-find ports on the back to plug in to. The power cable goes into the wall socket and the video cable goes to your tv. Nowadays, video game systems have either AV cables (red, yellow, and white) or component cables (red, blue, and green) that ship with them. Old systems like the NES may come with an old RF connection (the one that is reminiscent of a cable connection--witht the screw thing on the end). Old tvs may not have AV inputs for the RYW or RGB connections. These will require an RF converter.
Any recent tvs have RYW inputs. They are generally on the back, or on flat tvs on the side, and they are usually color coded to match the type of wires that go into them. Mono tvs have only a white (sound) and a yellow (video). Stereo tvs have a red (right sound) in addition to these. High-def tvs have component inputs as well for higher quality. If you have an xbox 360, find the RGB cables and then find the color coded component inputs on your tv. Then also plug in the red and white sound jacks. make sure your xbox cable is switched to the component setting. This is a little switch that is on the connector where the cable meets the xbox.
This is the gemeral way to hook up a video game system, Anything else will require more details.
Jul 29, 2008 | Video Game Consoles & Games
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
