Question about Hisense Televison & Video
My hisense 43 4k tv keeps reverting to 480i from 4k when i check the output it says 4k not recognised but then i reset the tv and go back into the picture output menu it lets me put 4k back on my tv
Hisense 4k 43" tv how to stop 4k res going back to 480i res. it only happens when i switch my xbox one s on i have to reset the tv every day which is a pain. plus since the hdr update came out the box is just greyed out how do i get to use hdr
Just bought this television at my local Wal-Mart it didn't have a remote was it suppose to have one
Posted on May 20, 2018
    Top Expert:
  • Hisense Master
  • 75,289 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Dec 27, 2016
Minue keeps flashing on and off the screen of my 40in hisense tv.
Try a reset to this TV, and then check. If it do not help, replace its main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 11, 2017 | Hisense Televison & Video
This keeps on popping up on my hisense tv screen and nothing seems to take it off , it just keeps on popping up, is there a way to fix this problem ?
Try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 31, 2015 | Hisense Televison & Video
Trying to hook up a playstation 2 to a sylvania LC195SLX tv
The PlayStation 2 may natively output video resolutions on SDTV and HDTV from 480i to 480p while other games, such as Gran Turismo 4 and Tourist Trophy are known to support upscaled 1080i resolution using any of the following standards: composite video(480i), S-Video(480i), RGB(480i/p,
Which output from the game to the TV are you using?
Apr 13, 2014 | Sylvania Televison & Video
Hisense tv is set on 480i need to set on 1080p
Unplugging the tv resets it and the remote works fine afterward. It happens now and then when you push too many buttons at the same time on the remote
Jul 07, 2012 | Hisense TL1700 17 in. LCD Television
My TV is only 480i. When my receiver reboots, I cannot see the settings menu to configure the receiver to output to 480i. I need to know the remote keystrokes to press to configure the receiver for...
You did not give your model number of receiver. Some of the ones from 2007 or so have a switch on the back for video resolution, 480i, 480p 720p 1080i so set this switch to 480i.
Mar 08, 2011 | Samsung HDTV Digital Terrestrial Receiver
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
When i turn on my ps3, there's no picture. I changed the cables and still no pic. it blinked on for a second and then nothing.
With the ps3 off and connected to the tv hold the power button down, keep it held down until you hear a couple strange beeps and it fully powers back off. That will reset the video output settings and if you switched televisions should enable you to see some picture, then go to display settings and configure it for the tv you are using specifically (480i/P,720P,1080i/P,etc)
Rylan
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
Unable to play DVD's
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Mar 19, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Adjusting the resolution from 480i to 1080i
Typically TVs will auto adjust to the input signal it receives. If your cable box is only outputting 480i then all the tv will show is 480i. Ensure you have a good 1080i signal going in to the unit and check again
May 04, 2009 | Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
113 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
