Question about Cell Phones
Need to switch memory to SD card on my Mobicel Trendy
  • 903 Answers
SOURCE: Video and still image - SD Memory Cards
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Posted on Aug 31, 2005
  • 903 Answers
SOURCE: SD Memory Cards to record in MPEG2
SOURCE: memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Posted on Jan 02, 2009
SOURCE: BenQ C850 Switch from internal memory to sd card?
Try other SD card. 99.99% sure that the card is not good. Borrow your card to someone to check your card with his camera,or Format the card from C850 Menu.
Posted on Dec 01, 2009
  • 24 Answers
SOURCE: my canon SD 750 camera does not read the sd card even when the sd card is not locked, how do i unlock the internal switch in the camera for the sd card?
Could be faulty sd card and you may need to try another one to see if you get the same message.
Posted on Nov 05, 2012
I hav mobicel trendy I for got my Gmail password please help
Call at +18002044427 Toll-Free Number for Gmail customer support service to resolve Gmail account issues.Google mail customer care helpline phone number 2016 ' recover gmail password
Apr 19, 2017 | Computers & Internet
Im using mobicel trendy and it was working now it says no sim card I have tried several times now to remove it and install it what can be a problem cell c 0781912510
You may need a new SIM, contact your local cell service provider for a new one, if that fails to fix the message the phone is defective.
Jan 27, 2017 | Cell Phones
Mobicel metro dont want download without sd card
Probably it needs SD card to store doenloaded files. Buy a 1 Gb SD card. Cheap!
SanDisk 1GB microSD card
May 15, 2015 | Cell Phones
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
Card locked
If your camera uses a SD memory card then -
SD and Mini SD memory cards SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 02, 2013 | Canon PowerShot SD600 Digital Camera
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
My SD memory card says its "unwriteable"
There is usually a switch on the adapter you are using that is there for write protection. The Micro sd card does not have one. Make sure it is not in the lock "position". See this website for more on memory cards and common problems. http://www.retire-asia.com/microsd.shtml I cut a little piece from the site that might help you
"There is no switch on the Micro SD card itself, but a standard-size-SD adapter (which the MicroSD needs to be plugged into for use with a card reader) and SD cards such as the SanDisk 4/8GB have a sliding write-protect switch similar to a 3.5 inch floppy disk. Data cannot be written if the slider tab is in the 'lock' position. The tab could be damaged or missing altogether. This is probably the first thing to check if you have an SD card write error problem. Using sticky tape (Scotch tape etc) to cover the switch slot might solve this problem, but it may need two or more layers before it works. Some SD adapters need the tab to be placed somewhere between the lock and open positions before data can be written to the card."
Mar 03, 2009 | SanDisk 2GB microSD Memory Card
Cell Phones Logo
103 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
