Question about Plumbing
My Davey bore pump is not pumping water. the pump is running and sounds normal. i am told by friends it needs priming but i do not know how to do that. Can someone talk me through it please?
  • 104 Answers
SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
Posted on Mar 17, 2009
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
SOURCE: Sprinkler pump keeps loosing it prime. Intake line
Check valve might be bad.
Posted on Jun 23, 2009
SOURCE: new 1/2 hp jet pump with tank not working
Your hose size is to small. Use a 2in black plastic line out to the lake. Inspect your foot valve, and
take your pump apart to see if you may have a pebble stuck in it, and remove the inner workings
and clean. Contaminates build up inside and need to be flushed out. Remember to replace the
gasket. Tighten all your hose clamps. Once your ready to start, spray shaving cream on your
fittings to see if your sucking air. I've been through it all and my pump works fine.
Chuck
Posted on Jul 06, 2009
dmftrucker
  • 1922 Answers
SOURCE: bad leak, dont know if its water pump or thermostat
sounds like your water pump gasket has a hairline crack in it and as engine warms it expands and leaks more
Posted on Sep 28, 2009
Davey XJ70 pumps bore water but flow dwindles when garden hose attached thus requiring pump to be turned off to stop burn out. Marc
possible it is a jet pump that has a return hose back to the foot valve to assist the pump to lift the bore water higher to work the pump
if that is the case ,when you turn on the tap on the pressure to the lift jet is reduced and so the pump cannot lift the water from the bore --it runs out of water
the fix here is to restrict the flow out of the tap so that jet pressure is maintained--- don't turn the tap on more than 1 turn
the reason is the lift height is too great ,indicating that the bore water level is lower than it normally is
Feb 22, 2017 | Water Garden
My rain bank davey pump is flashing a yellow light
if not running , check for water supply to pump or air in pump
prime and restart
Jan 29, 2017 | Cars & Trucks
Davey 95s elecric water pump ran dry turned it of re primed now wont start
Richard, if your saying pump will not start after running dry, it is probably seized or burnt out.
Mar 05, 2016 | Cars & Trucks
My pump is running but not drawing water from the bore hole. What is the problem and how can I solve it?
the pump needs priming first as the water in the pipe to the foot valve has drained out ( foot valve held open by sand grains and not sealing off properly)
the bore is empty
water level too low for the pump to lift water
Dec 29, 2015 | Cars & Trucks
Hi guys I have 2 grundfos cri10 vertical pumps (just for water pressure) I changed the expansion vessel which blew and I have primed the vent plug but for some reason every time I power the pump up it goes...
indicates no water supply for the pump
check tap from the tank is turned on
if the vertical ? pump is a submersible (in well type ) check for water in the bore/well
If a jet pump make sure that the whole jet system is primed -not just the pump and again make sure that there is water in the well/bore
Jan 10, 2018 | Grundfos Pumps Grundfos CRI 10 Stack Kit
How do you prime the siena?
Schaerer Siena machines can become airlocked from time to time leaving the pump running yet sounding rough. Easiest way of remedying this is by running the hot water (either by pressing the jug button or turning the hot water knob on the side depending on which model you've got) option through the silver wand. Once you get a strong water flow through this then the machine pump has been primed and you can then begin making coffee as normal. You'll notice the sound the pump makes will change as the water comes through.
Dec 08, 2012 | Schaerer Siena Espresso Machine
Saeco rio profi making a loud noise no water coming out
Someone onCoffee Geek had this to say and it sounds like it could be the same problem:When I first got my machine--a steal from a fellow barista friend for $40!--It had been sitting dry for about 18 months, and I had the same problem with the pump. After trying some things myself, I eventually called the manufacturer's help line and was told I needed to manually prime it. I used a little squeeze bottle full of water to slowly fill the intake tubing with water and turned on the machine and opened the steam/hot water valve which turned on the pump. After some stuttering, it caught and has been fine ever since. So yes, I would recommend manually priming and then running water through the pump, boiler, and steam wand until all air is out of the system. Hopefully that will fix you up.
Aug 05, 2012 | Saeco RIO Profi
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
No water supply to house
i have a hs50-05t with a torrium controller it only works when you hold the prime button in
Nov 21, 2009 | Plumbing
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
