Question about Dishwashers
Sorry that should have been 0B76 model on that last question re the control panel not lighting up.
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
I can't get the heat element to turn on
SORRY FRAN but without a make,model we have no way of looking for assistance
Sep 06, 2015 | Ovens
My Aiwa CX-NAJ80 system will not come off Standby.
Sorry but the control board is shot that's why there inexpensive to purchase they only last for 3 to 5 years
Mar 02, 2014 | Aiwa Audio Players & Recorders
The hi temp light keeps flashing on my whirlpool dishwasher.
Not sure which particular model you have got. If turning off the mains power off and on is not helping then you will need to reset the controller. "press your "Normal" button then your "Heated Dry" button alternatively several times (quickly). This should reset the control panel and allow you to resume normal functioning."
Read more: http://forum.appliancepartspros.com/dishwasher-repair/11043-control-panel-lights-blinking.html#ixzz2psYY7aFn
Jan 08, 2014 | Whirlpool Dishwashers
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Door light, on/off switch, water and ice dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it.
if you are still having trouble please respond with a model number
Apr 15, 2009 | Refrigerators
Dishwasher works only in Rinse and no lights on the Control Panel
I HAVE SEEN THIS BEFORE ON SEVERAL DIFFERENT MAYTAG MODELS AND EACH TIME, IT HAS BEEN THE ACTUAL TOUCH PANEL WHERE YOU MAKE YOU SELECTIONS. I HAVE PROBABLY SEEN A DOZEN OF THESE IN THE LAST COUPLE OF YEARS. HOPE THAT HELPS.
Jan 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
Systemax model GL-821A
it sound like a monitor issue, does it have lines, or turn white?
sorry to say all monitors do not last as long as the computer
Jun 05, 2008 | Systemax Scanport Gem GL-821A 17 in. Flat...
MY HAMILTON BEACH WATER DISPENSER MODEL 87307 SERIES A1360CT WILL HEAT BUT NOT COOL THE WATER.
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
Apr 21, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
