Question about Car Audio & Video
ModelHCD RG490 When switched from standby to tuner or cd or tape somekind of a timer kicks in "relay" appears on screen and timer ticks off 3 or 4 seconds then it go back to standby
Before going back to Standby "Eject" appears on screen
  • 22 Answers
SOURCE: returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Posted on Jan 12, 2008
SOURCE: Teac A-H300 Amplifier
I found the thread of one of my speaker cables was touching the backboard of the amp and shorting out - problem solved!
Posted on Oct 20, 2008
SOURCE: My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Posted on Jan 08, 2009
  • 32 Answers
SOURCE: idlcd32tv27hd comes on for 1 second then goes to standby
Posted on Mar 15, 2009
  • 8457 Answers
SOURCE: my sharp aquos lc-32p55e tv.When u swith it on it
Ur power board have dead parts,Check parts like Capacitors puff up or burst open.Know how to solder?Or replaced the the whole power board,Websites, have reburbish power board.
Posted on Jan 13, 2010
Will not switch on
Probably an electrolytic capacitor blew... should be obvious if you remove the case. The tops blow off or split... may leave residue.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
I have a Amp,CD player,Tuner,and DVD player. no a tape can i conect all, with out a tape deck through eqeualizer.
You can connect the EQ on the tape in/output of your amplifier. Tape out (or monitor out) to the input of the EQ and tape in to the output of the EQ.
Listen to the tuner and than switch to the tape input, the tuner input will be still active. But in the tape "mode" your EQ will be active too.
Jan 10, 2010 | Yamaha EQ-70 Home Equalizer
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
Tv ticks like a clock,no standby light, no picture
tick sounds is the relay, the relay is trying to oscillate the power, but its failed because of shorted regulator or any parts are shorted this is what happen cant start normally..
Apr 25, 2009 | Samsung Televison & Video
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Need help
try to press the timer button repeatedly untill u see time 00 is desplayed may be u solve your problem if it is in sleep timer mode and if u managed to rset timer to 00 and the problem persist your tv has a high voltge problem it delay to charge the tube.
Sep 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Driving along and radio stopped working, the word "ocer" came across face of radio. Now, radio and cd player both will not work. Help!
I pushed the reset button and "standby" mode appeared. I proceeded to hit the source button and switched to tuner and cd player with no problems.
Jul 02, 2008 | Kenwood Car Audio & Video
Mar 30, 2008 | Teac A-H300 Amplifier
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
