Question about Sharp AR-5316 Advanced Digital Imager Copier
U2-40 error on Sharp AR 5127 copier
Experts,
The copier displays U2-40 call for service... how can we fix this..
Please help me experts...
Faye
  • fay april Jul 22, 2009
    EXPERT RONNIE59
    Sir, Thank you very much... problem solved... it really helped a lot. since we are geologically located at the heart of the philippines and need 12 hours of sea travel just to get here, it is hard for us to call for service from sharp...
    Thank you very much, you are really an expert.
    FAYE
    Sniper:
  • 118 Answers
Try this pres the ff: # >interrupt> C >Interrupt
input 16 then follow instruction
this is related when you install not original toner or not compatible one
Posted on Jul 21, 2009
  • Ronnie Gregorio Jul 22, 2009
    Hi Faye,
    Proudly Pinoy to it"s from Dubai , Thanks for the complement please rate my solutiton .Salamat
    Ronnie
    Problem Solver:
  • 9 Answers
Http://www.tradebit.com/filedetail.php/185184978-sharp-ar-5316ar-5320-service-manual
Posted on Aug 04, 2012
Thank you i will try it
Posted on Nov 25, 2009
Posted on Aug 31, 2009
Pls . help me experts , i have kyocera km3050 copier but the lcd touchscreen is not responding but days past when it still responding its getting hard to respond. please help me with this experts
A hard reset can clear minor error codes. A lot of times you do not really need to call for your support contractor. Sometimes errors stop the function of a machine, but the machine could still function properly with a hard reset. Perhaps there is a better description than hard reset, as "reset disable function" is a little bit confusing and not a phrase you were likely look for.
Contact your service provider before following these instructions.
Use at your own risk. Perhaps there is a possibility of causing damage. Again, contact your provider.
From our copier service company:
This reset is used for two purposes:
1) reset any data that may be "hung up" in the hard drive.
2) reset an error code and attempt to continue use. (If the error recurs, then you should escalate to whomever supports the copier.
Hard Reset Procedure:
Press Status button
Enter 10871087 - You are now in Maintenance Mode
Enter 906 (do not enter any other numbers!)
Press Start
Press Execute
Press Start
Copier tells you to turn it off/on
Turn off power by switch on right side of copier (hard power off)
Turn on power by switch on right
I have seen to use code 163 instead of 906. I don't know what this does. Again, consult experts before using this code or any others.
Feb 03, 2015 | Kyocera Mita KM3050 Black Toner Cartridge...
What do various levels indicate
Levels on Fixya indicate which experts your question has been viewed by. Levels are determined by the amount of problems an expert has solved. Level 1 experts are typically newer experts while level 3 are experts who have provided many solutions.
Hope that helps and for even more info check out the Fixya FAQ page.
Mar 31, 2013 | FixYa Service
Hi my aircondition was stock up the light display are 2 the timer and the operation i don't know how to remove it and back to the normal can you please help me? thank you!
This is a difficult question to answer.
Try re-posting your question saying what type of timer you are dealing with.
What the timer controls.
What symptoms you have observed.
What you have done so far to fix the problem.
This will help the experts at fixya give the do-it-yourselfer a solid helpful answer.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Hardware & Accessories
Dell All-in-one Printer 966 The wheel that holds the belt that the ink cartridge tray rides on popped out. Having trouble getting it back in.Help?
Actually need to tighten the belt and also fix the catridge with the help of expert engineers or service center experts.
Revert back for more assistance.
Feb 03, 2010 | Dell Office Equipment & Supplies
Hp laserjet 1100
This is due to tufflon drum is having the issue. Repair/replace the samme with the help of expert engineer/Service center experts will resolve your problem.
Jan 28, 2010 | HP LaserJet 1100 Printer
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Getting virtual memory low & needing to get to the control panel
If you think that you cant able to fix your problem yourself and need remote support by experts at cheap rates so contact us—
frankmartin90@gmail.com
Note:
1) Its a remote support so, the experts come in to your computer and fix your problem.
2) We solve only computer problems by remote support.
3) The other problem is not remotely supported but answered by experts so; feel free to ask any question on any problem.
4) Did not need to pay in advance pay when you get solution.
  SO WHY YOU ARE WAITING ASK YOUR QUESTION TODAY
Jan 03, 2009 | Dell Dimension 3000 PC Desktop
Sharp AR-5316 Advanced Digital Imager Copier Logo
989 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
