Question about Teac Audio Players & Recorders
I have a TEAC BX 330 amplifier that I bought secondhand. It has speaker configurations; A or B or Off.
When I patched a CD player into the unit I could see activity on the LED VU meters UNTIL I select the speakers that are connected to A or B (In tried both) or plug in headphones. Once I do either of those things the VU stop working.
  • 624 Answers
SOURCE: laptop speakers stopped working
Hello fadesit, It sounds like the headphone socket is sticking/defective. When you insert the jack into the socket a contact is broken to disable the external speakers, when you remove the jack the connection is resumed. Due to the amount of work this will take and the possibility of causing other problems in the process I would check to see if the warranty is still in effect first. If not then the next thing to ask is do you have the tools, mechanical aptitude, patience and ability to risk damaging your laptop to do this yourself? If you want to go the do it yourself route let me know and I?ll post some disassembly instructions later tonight otherwise please don?t forget to rate the posting.
Posted on Jan 17, 2007
  • 1066 Answers
SOURCE: 1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
Posted on May 17, 2008
  • 1605 Answers
SOURCE: My headphones won't work!
look at the headphone jack, if it has 3 band, it is a stereo jack. the computer is mono.
you need a 2 band jack.
if you look at the jack on the computer, you will see blue(left) and green (right). you canna try to use the green jack.
go to any electroic shop and get a stereo to mono converter.
Posted on Dec 05, 2008
  • 304 Answers
SOURCE: I have a TEAC AG-500
hi there.
try checking and correcting the connections. see and fix any possible loose connections or connectors on the receiver, also check the wire quality
Posted on Dec 06, 2008
SOURCE: muffled sound from speakers when connected to laptop via amplifier
You need to buy an analog to digital converter box if you want to get superb sound quality from your computer.
Posted on Mar 10, 2009
Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Teac GF-350 CD Shelf System
What speakers are for MDS JE 330
Any kind you want. The MDS JE330 needs to be connected to an amplifier to use regular loudspeakers, so the choice depends on your amplifier, room size and budget.
You can also connect small active or passive speakers designed for portable units such as mp3 players or those used on desktop pc's to the headphone socket, but the sound quality won't be very good.
Sep 22, 2010 | Sony MDS-JE330 Mini Disc Player
Just wondered if i can connect my speakers straight to cd player or do i need to go through an amp Thanks
Component CD players like yours must be used with an amplifier. Their output is called "line level" and isn't beefy enough to drive speakers directly. An amplifier is needed to boost those line level signals to speaker level. The same is true for other components like tape decks, DVD players and so on. A CD player may have a headphone output jack, though, since headphones don't require the same power levels as speakers. So you could use the player by itself for headphone listening.
Hope this has cleared the air for you. Thanks for using Fixya!
Feb 10, 2010 | Teac CD-P1160 CD Player
How to hook it up to a amplifier
sound source out(dvd-cd player)-------------to teac eqa-5 in-----------------teac out---------to amp line in.
Oct 31, 2009 | Teac EQA-120 Home Equalizer
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
CD ticking problem!?
please check the is on five or more rubber mounts one of rhat rubber mount damaged. or is anything stuc inside the player .
if you have warranty go with problem occurd cd and sho it to them.
they have to fix it .isnt it?
Jan 14, 2009 | Teac Audio Players & Recorders
CD player ticking??
laser probably not tracking properly,get replacement if you can
Jan 14, 2009 | Onkyo DX-C340 CD Player
I have a teac DJ-505 jukebox which displays error 00001 sumtimes and then error 00004 sumtimes is the unit rubbish
Hello There
I have bought a Teac Jukeboc Digital Model number dj505
Could you please tell me how to turn Volume up to Speakers Please
Jul 29, 2008 | Teac Televison & Video
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
